I have a pond that has an issue, sometimes the water runs out of pond uncontrollable and my fish may die...
Because this is a bit WERY IMPORTANT, I hope you can quick give me a hand
I use an ESP8266 board, compile as NODE MCU 1.0
I made a sensor that gives input if water is running, the status "water is running" I plan to send to Home Assistant as a string 1 (high)
nor: vann renner = en: water running
Under is my code that compiles with error:
D:\Arduino2024\FilterFultv3\FilterFultv3.ino: In function 'void loop()':
FilterFultv3:95:21: error: 'vannRennerTopic' was not declared in this scope; did you mean 'vannRenner'?
95 | client.publish(vannRennerTopic.c_str() , vannRennerMsg);
| vannRenner
exit status 1
Code:
#include <ESP8266WiFi.h>
#include <PubSubClient.h> // MQTT
const char* ssid = "X"; // Your WiFi network SSID
const char* password = "Y"; // Your WiFi network password
const int buttonPin = D2; // D2 pin
int buttonState = 0; // variable for reading the button status
int lastButtonState = 0; // variable to store the previous button state
// MQTT
WiFiClient espClient;
PubSubClient client(espClient);
int maxRetryMQTT = 3;
int retryMQTT = 0;
String MQTTstatus = "_"; // For å skrive til serial at kobling til HA er OK
const char* mqtt_username = "x"; // MQTT username virker 2023.07.05
const char* mqtt_password = "y"; // MQTT password virker 2023.07.05
const char* mqtt_clientID = "dam"; // MQTT client ID, må være unikt pr IoT
char vannRennerMsg[10];
String vannRenner = "0";
IPAddress MQTTserver(192, 168, 0, 60); //MQTT server IP
Serial.begin(115200); // initialize serial communication
pinMode(buttonPin, INPUT); // set the D2 pin as an input
digitalWrite(buttonPin, LOW); // enable internal pull-down resistor
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.print("Connecting to ");
Serial.println(ssid);
Serial.print(".");
// Print connection established
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
// kobler til mqtt
if (!client.connected()) {
while (!client.connected() && retryMQTT < maxRetryMQTT) {
Serial.println("Kobler til MQTT...");
if (client.connect(mqtt_clientID, mqtt_username, mqtt_password)) {
Serial.println("MQTT koblet til! IP 192.168.0.60:1883, web :8123");
retryMQTT = 0; // Reset the retry count if the connection is successful
MQTTstatus = "Koblet til HA";
Serial.print("Feila å koble til MQTT, Return Code = ");
Serial.println(client.state());
retryMQTT++;
MQTTstatus = "Ikke koblet til HA, RC = " + client.state();;
//ESP.restart(); // ###################### behold denne muligheten se på versjon tidligere
// read the state of the pushbutton value
buttonState = digitalRead(buttonPin);
// check if the button state has changed
if (buttonState != lastButtonState) {
// check if the pushbutton is NOT pressed
if (buttonState == HIGH) {
Serial.println(" Det renner ikke vann");
Serial.println(" Det renner vann");
vannRenner = "1"; // setter til 1, high
//tildeling av topic
String vannRenner = "dam/vannRenner";
// Convert payload into Msg strings. PASS PÅ INT VS FLOAT %d vs %f
snprintf(vannRennerMsg , 10, "%d" , vannRenner);
// Publish message to Home Assistant
// update lastButtonState to the current buttonState
lastButtonState = buttonState;
delay(100); // small delay to debounce the button
So where did you declare vannRennerTopic? It's nowhere to be found.
You might very well have a problem there as well.
Two variables called vanRenner, one global and one local. Which one will be used in the snprintf()?
snprintf() can not handle Strings. And %d would be the wrong format specifier to convert a text. If your vanRenner variable is supposed to only hold the values "0" and "1", use an int instead of a String; the %d will work for that.
I suspect that String vannRenner = "dam/vannRenner"; should be String vannRennerTopc = "dam/vannRenner";
That's really true. Once a broken sensor said the water level in the river was low, really low. The draining of the river closed up. One fire station was flooded as well as a nearby amusement park. The flood spread into yard for rain deer that drank the dirty water, and died....
To start, I dont use automation as life and death, but while I try to figure out what's happening I use some surveillance to help find the main reason. Actually I hate using automation for this kind of systems, so this is a temporarilly installation.
But I dont manage to find fault in my code, so now I was hoping to get some code help.
Below a code that compiles; if it works as you expect is another question. Please compare it with your original; changes are marked with sterretje.
// MQTT
int retryMQTT = 0;
// sterretje
//String vannRenner = "0";
uint8_t vannRennerFlagg = 0;
// Connect to WiFi
Serial.print(".");
Serial.println("");
// kobler til mqtt
retryMQTT++;
// sterretje
//vannRenner = "1"; // setter til 1, high
vannRennerFlagg = 1;
// sterretje
//String vannRennerTopic = "dam/vannRenner";
char topic[] = "dam/vannRenner";
// sterretje
//snprintf(vannRennerMsg , 10, "%d" , vannRenner);
snprintf(vannRennerMsg , 10, "%d" , vannRennerFlagg);
client.publish(topic, vannRennerMsg);
Notes:
You do set the flag vanRenner but you never clear it. This might be intentional or not.
/home/wim/Downloads/arduino-1.8.19-esp8266/portable/sketchbook/libraries/pubsubclient-master/src/PubSubClient.cpp: In member function 'boolean PubSubClient::publish_P(const char*, const uint8_t*, unsigned int, boolean)':
/home/wim/Downloads/arduino-1.8.19-esp8266/portable/sketchbook/libraries/pubsubclient-master/src/PubSubClient.cpp:523:16: warning: comparison of integer expressions of different signedness: 'unsigned int' and 'int' [-Wsign-compare]
523 | return (rc == expectedLength);
name=PubSubClient
version=2.8
author=Nick O'Leary nick.oleary@gmail.com
maintainer=Nick O'Leary nick.oleary@gmail.com
sentence=A client library for MQTT messaging.
paragraph=MQTT is a lightweight messaging protocol ideal for small devices. This library allows you to send and receive MQTT messages. It supports the latest MQTT 3.1.1 protocol and can be configured to use the older MQTT 3.1 if needed. It supports all Arduino Ethernet Client compatible hardware, including the Intel Galileo/Edison, ESP8266 and TI CC3000.
category=Communication
url=http://pubsubclient.knolleary.net
architectures=*
const char* ssid = ""; // Your WiFi network SSID
const char* password = ""; // Your WiFi network password
int vannRennerFlagg = 0;
int previousState = 0;
// MQTT
int retryMQTT = 0;
const char* mqtt_username = ""; // MQTT username virker 2023.07.05
const char* mqtt_password = ""; // MQTT password virker 2023.07.05
PrintFileNameDateTime();
client.setServer(MQTTserver , 1883); // MQTTk
// Connect to WiFi
Serial.print(".");
Serial.println("");
// kobler til mqtt
Serial.println("Connect to MQTT...");
Serial.println("MQTT IP 192.168.0.60:1883, web :8123");
MQTTstatus = "Connect to til HA";
Serial.print("Error MQTT connection, Return Code = ");
retryMQTT++;
MQTTstatus = "Not connected to HA, RC = " + client.state();;
vannRennerFlagg = 0; // nullstiller etter en lekkasje
Serial.print(" Det renner ikke vann, sender verdi: ");
Serial.println(vannRennerFlagg);
client.loop(); // MQTT loop
// 1 lager topic
// 2 konverterer variable til string
snprintf(vannRennerMsg, 10, "%d" , vannRennerFlagg);
// 3 Publish message to Home Assistant
client.publish(vannRennerTopic.c_str(), vannRennerMsg);
vannRennerFlagg = previousState; // 1 betyr at det renner vann
vannRennerFlagg++;
previousState = vannRennerFlagg; // holder styr på antall ganger det har runnet vann
Serial.print(" Det renner vann, sender verdi: ");
// 1 lager topic
// helper-functions
void PrintFileNameDateTime() {
Serial.println( F("Code running comes from file: ") );
Serial.println( F(__FILE__) );
Serial.print( F("Compilert") );
Serial.print( F(__DATE__) );
Serial.print( F(" ") );
Serial.println( F(__TIME__) );
