MQTT won't connect when using example code aws_iot_WIFI.ino
Im using the example code aws_iot_WIFI.ino. The device successfully connects to the internet but never manages to connect to the aws MQTT. I have checked the ports are open on my router and I ping the URL for the endpoint successfully.
I created a certificate using the key from the nano module. Ive see on git hub others have had the same issue, has anybody seen this before and can help
  AWS IoT WiFi
  This sketch securely connects to an AWS IoT using MQTT over WiFi.
  It uses a private key stored in the ATECC508A and a public
  certificate for SSL/TLS authetication.
  It publishes a message every 5 seconds to arduino/outgoing
  topic and subscribes to messages on the arduino/incoming
  topic.
  The circuit:
  - Arduino MKR WiFi 1010 or MKR1000
  The following tutorial on Arduino Project Hub can be used
  to setup your AWS account and the MKR board:
  https://create.arduino.cc/projecthub/132016/securely-connecting-an-arduino-mkr-wifi-1010-to-aws-iot-core-a9f365
  This example code is in the public domain.
#include <ArduinoBearSSL.h>
#include <ArduinoECCX08.h>
#include <ArduinoMqttClient.h>
#include <WiFiNINA.h> // change to #include <WiFi101.h> for MKR1000
#include "arduino_secrets.h"
/////// Enter your sensitive data in arduino_secrets.h
const char ssid[]        = SECRET_SSID;
const char pass[]        = SECRET_PASS;
const char broker[]      = SECRET_BROKER;
const char* certificate  = SECRET_CERTIFICATE;
WiFiClient    wifiClient;            // Used for the TCP socket connection
BearSSLClient sslClient(wifiClient); // Used for SSL/TLS connection, integrates with ECC508
MqttClient    mqttClient(sslClient);
unsigned long lastMillis = 0;
  while (!Serial);
  if (!ECCX08.begin()) {
    Serial.println("No ECCX08 present!");
    while (1);
  // Set a callback to get the current time
  // used to validate the servers certificate
  ArduinoBearSSL.onGetTime(getTime);
  // Set the ECCX08 slot to use for the private key
  // and the accompanying public certificate for it
  sslClient.setEccSlot(0, certificate);
  // Optional, set the client id used for MQTT,
  // each device that is connected to the broker
  // must have a unique client id. The MQTTClient will generate
  // a client id for you based on the millis() value if not set
  // mqttClient.setId("clientId");
  // Set the message callback, this function is
  // called when the MQTTClient receives a message
  mqttClient.onMessage(onMessageReceived);
  if (WiFi.status() != WL_CONNECTED) {
    connectWiFi();
  if (!mqttClient.connected()) {
    // MQTT client is disconnected, connect
    connectMQTT();
  // poll for new MQTT messages and send keep alives
  mqttClient.poll();
  // publish a message roughly every 5 seconds.
  if (millis() - lastMillis > 5000) {
    lastMillis = millis();
    publishMessage();
unsigned long getTime() {
  // get the current time from the WiFi module
  return WiFi.getTime();
void connectWiFi() {
  Serial.print("Attempting to connect to SSID: ");
  Serial.print(ssid);
  Serial.print(" ");
  while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
    // failed, retry
    Serial.print(".");
    delay(5000);
  Serial.println("You're connected to the network");
void connectMQTT() {
  Serial.print("Attempting to MQTT broker: ");
  Serial.print(broker);
  Serial.println(" ");
  while (!mqttClient.connect(broker, 8883)) {
    // failed, retry
    Serial.print(".");
    delay(5000);
  Serial.println("You're connected to the MQTT broker");
  // subscribe to a topic
  mqttClient.subscribe("arduino/incoming");
void publishMessage() {
  Serial.println("Publishing message");
  // send message, the Print interface can be used to set the message contents
  mqttClient.beginMessage("arduino/outgoing");
  mqttClient.print("hello ");
  mqttClient.print(millis());
  mqttClient.endMessage();
void onMessageReceived(int messageSize) {
  // we received a message, print out the topic and contents
  Serial.print("Received a message with topic '");
  Serial.print(mqttClient.messageTopic());
  Serial.print("', length ");
  Serial.print(messageSize);
  Serial.println(" bytes:");
  // use the Stream interface to print the contents
  while (mqttClient.available()) {
    Serial.print((char)mqttClient.read());
Welcome to the forum
Why did you start a topic in the Uncategorised category of the forum when its description is
:warning: DO NOT CREATE TOPICS IN THIS CATEGORY :warning:
Your topic has been moved to the Programming category
Apologies I thought I had changed it in the drop down menu
