my mfrcc522 led is bright but it cant scan cards as well i am using it with esp8266 the code is
#include <deprecated.h>
#include <MFRC522.h>
#include <MFRC522Extended.h>
#include <require_cpp11.h>
- Project: RFID attendance system using NodeMCU
- Date: 6/03/2024
This code was created by Electronics Tech channel for
the RFID attendance project with NodeMCU.
//c:\Users\Himanshu\Downloads\RFID-Attendance-system-V2.0-master\RFID-Attendance-system-V2.0-master\NodeMCU_RFIDv2.0\NodeMCU_RFIDv2.0.ino******libraries********************************
//RFID-----------------------------
#include <SPI.h>
//NodeMCU--------------------------
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#define SS_PIN D2 //D8
#define RST_PIN D1 //D3
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
/* Set these to your desired credentials. /
const char ssid = "5";
const char password = "123456789H";
const char device_token = "a28e4d22c5b74030";
String URL = "http://192.168.43.187/rfidattendance/getdata.php"; //computer IP or the server domain
String getData, Link;
String OldCardID = "";
unsigned long previousMillis = 0;
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
connectToWiFi();
//check if there's a connection to Wi-Fi or not
if(!WiFi.isConnected()){
connectToWiFi(); //Retry to connect to Wi-Fi
if (millis() - previousMillis >= 15000) {
previousMillis = millis();
OldCardID="";
delay(50);
//look for new card
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;//got to start of loop if there is no card present
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;//if read card serial(0) returns 1, the uid struct contians the ID of the read card.
String CardID ="";
for (byte i = 0; i < mfrc522.uid.size; i++) {
CardID += mfrc522.uid.uidByte[i];
if( CardID == OldCardID ){
return;
else{
OldCardID = CardID;
// Serial.println(CardID);
SendCardID(CardID);
//send the Card UID to the website*
void SendCardID( String Card_uid ){
Serial.println("Sending the Card ID");
if(WiFi.isConnected()){
HTTPClient http; //Declare object of class HTTPClient
//GET Data
getData = "?card_uid=" + String(Card_uid) + "&device_token=" + String(device_token); // Add the Card ID to the GET array in order to send it
//GET methode
Link = URL + getData ;
http.begin(Link); //initiate HTTP request //Specify content-type header
int httpCode = http.GET(); //Send the request
String payload = http.getString(); //Get the response payload
// Serial.println(Link); //Print HTTP return code
Serial.println(httpCode); //Print HTTP return code
Serial.println(Card_uid); //Print Card ID
Serial.println(payload); //Print request response payload
if (httpCode == 200) {
if (payload.substring(0, 5) == "login") {
String user_name = payload.substring(5);
// Serial.println(user_name);
else if (payload.substring(0, 6) == "logout") {
String user_name = payload.substring(6);
else if (payload == "succesful") {
else if (payload == "available") {
delay(100);
http.end(); //Close connection
//**connect to the WiFi
void connectToWiFi(){
WiFi.mode(WIFI_OFF); //Prevents reconnection issue (taking too long to connect)
WiFi.mode(WIFI_STA);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("Connected");
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
the output is only : 15:19:01.811 -> ⸮⸮⸮⸮
please help me it is my major project
