MRK WAN 1300 Frequency (433/915)mhz
On the website it is mentioned that MKR1300 comes with the following frequency :
1-433 mhz
2-915 mhz
3-868 mhz
Can any one please elaborate that, does a single unit support all the frequencies or each single unit support a single frequecy at a time.
Hello,
Each board supports all the three frequencies but it depends on your location. You have to select the country/band by passing in the argument to begin, modem.begin().
Here is the reference page MKRWAN - Arduino Reference.
Uh, so which one is EU433
Thanks
if (!LoRa.begin(433E6))
Solved
Just to clarify, the solution @MeandMrsJones shared is for when you're using the LoRa library:
The reference page URL Sravya shared earlier is for the MKRWAN library.
