I need to know how to use the DAC A0 Pin. What I need to do is read in an analog and scale it and then output on the DAC A0 pin. I have been unable to find any information on how to set it up.
You can use the analogWrite function. Here is a simple example. The signal level change at a rate of around 10kHz. Without delay you get 350kHz. I used the Arduino Nano 33 IoT which is the little version of your board.
Simple DAC example
The sketch demonstrates the use of the SAM21 Digital-to-Analog converter.
The circuit:
- Arduino Nano 33 IoT
This example code is in the public domain.
#define DAC_ANALOG_RESOLUTION 10
Serial.begin( 9600 );
while ( !Serial );
Serial.println( "Arduino Nano 33 IoT - DAC example" );
pinMode( DAC0, OUTPUT );
analogWriteResolution( DAC_ANALOG_RESOLUTION );
static uint32_t loopCount = 0;
loopCount = loopCount + ( 1u << ( DAC_ANALOG_RESOLUTION - 2 ) ) % ( 1u << DAC_ANALOG_RESOLUTION );
analogWrite( DAC0, loopCount );
delayMicroseconds( 100 );
