MS5607 altimeter 29124
Hi All,
I am getting the following error when I use MS5607.
PROM COEFFICIENTS ivan
Error reading PROM 1
0
0
0
0
0
0
Actual TEMP= 20.00 Actual PRESSURE= 0.00
RAW Temp D2= 4294967295 RAW Pressure D1= 4294967295
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
I have referred to previous forum question regarding this (from 2012) but once they have the code attached there is some result. But for me it is always these values above. I understand that even if I dont connect any thing to SDA and SCL I will get the above result. Which means my sensor is not being detected. Anyone has a solution of how to make it visible to my arduino??.
I have attached SDA to analog pin4
SCL to analog pin5
5V to Vin
GND to Gnd
Please help.
Thanks,
Sri
sketch_jul26apressuretrial.ino (3.23 KB)
I don't want to delete this post.
But I got the below info and found out that SDA and SCL depends on the board we use.
Now I get the output as expected.
Please consider this thread as closed.
For more help on this follow the below thread.
http://forum.arduino.cc/index.php/topic,103377%20-
Regards,
Sri
