MS5611 Issue ?
Hi Guys
I bought a MS5611 sensor and have a question. I got it working and reading F° and Inches of Hg. All is fine until it gets down to 67° then it gets this reading “Actual TEMP = 251129.37 Actual PRESSURE= 9973.04” If I warm the sensor up it goes back to reading correctly. Does anyone have an idea what is going on ?
Thanks GD
#include <Wire.h>
#define ADDRESS 0x77 //Or this address 0x76
// This Sketch reads in F° and Inches of Hg
// SCL to Arduino Pin A5
// SDA to Arduino Pin A4
// VCC to 3.3 Volts
// GND to Ground
uint32_t D1 = 0;
uint32_t D2 = 0;
int64_t dT = 0;
int32_t TEMP = 0;
int64_t OFF = 0;
int64_t SENS = 0;
int32_t P = 0;
uint16_t C[7];
float Temperature;
float Pressure;
// Disable internal pullups, 10Kohms are on the breakout
 PORTC |= (1 << 4);
 PORTC |= (1 << 5);
  Wire.begin();
  Serial.begin(9600); //9600 changed 'cos of timing?
  delay(100);
  initial(ADDRESS);
  D1 = getVal(ADDRESS, 0x48); // Pressure raw
  D2 = getVal(ADDRESS, 0x58);// Temperature raw
  dT   = D2 - ((uint32_t)C[5] << 8);
  OFF  = ((int64_t)C[2] << 16) + ((dT * C[4]) >> 7);
  SENS = ((int32_t)C[1] << 15) + ((dT * C[3]) >> 8);
  TEMP = (int64_t)dT * (int64_t)C[6] / 8388608 + 2000;
  Temperature = (float)TEMP / 100 * 1.8+32;
  P  = ((int64_t)D1 * SENS / 2097152 - OFF) / 32768;
  Pressure = (float)(P / 100)*  00.0295299830714;
  Serial.print("     Actual TEMP  =  ");
  Serial.print(Temperature);
  Serial.print("      Actual PRESSURE= ");
  Serial.print(Pressure);
  Serial.print(" RAW Temp D2=  ");
  Serial.print(D2);
  Serial.print(" RAW Pressure D1=  ");
  Serial.println(D1);
//  Serial.print(" dT=  ");
//  Serial.println(dT); can't print int64_t size values
  Serial.print(" C1 = ");
  Serial.println(C[1]);
  Serial.print(" C2 = ");
  Serial.println(C[2]);
  Serial.print(" C3 = ");
  Serial.println(C[3]);
  Serial.print(" C4 = ");
  Serial.println(C[4]);
  Serial.print(" C5 = ");
  Serial.println(C[5]);
  Serial.print(" C6 = ");
  Serial.println(C[6]);
//  Serial.print(" C7 = ");
//  Serial.println(C[7]);
long getVal(int address, byte code)
  unsigned long ret = 0;
  Wire.beginTransmission(address);
  Wire.write(code);
  Wire.endTransmission();
  delay(10);
  // start read sequence
  Wire.write((byte) 0x00);
  Wire.requestFrom(address, (int)3);
  if (Wire.available() >= 3)
    ret = Wire.read() * (unsigned long)65536 + Wire.read() * (unsigned long)256 + Wire.read();
  else {
    ret = -1;
  return ret;
void initial(uint8_t address)
  Serial.println("PROM COEFFICIENTS ivan");
  Wire.write(0x1E); // reset
  delay(10);
  for (int i=0; i<6  ; i++) {
    Wire.write(0xA2 + (i * 2));
    Wire.requestFrom(address, (uint8_t) 6);
    delay(1);
    if(Wire.available())
       C[i+1] = Wire.read() << 8 | Wire.read();
    else {
      Serial.println("Error reading PROM 1"); // error reading the PROM or communicating with the device
    Serial.println(C[i+1]);
Hi Guys
I also went back to reading C° and Millibar and when the temp gets below 20.00° C it does the same thing.
GD
Use this line:
dT  = D2 - ((uint64_t)C[5] << 8);
instead of
Hi Sulfuric Acid :) Thanks you for your help ! That was the cure.
GD
