MSF Radio Time Code Signal Atomic Clock Receiver
Greetings! I've just bought one of these tiny little atomic time signal receivers for using in a chronulator i'm building.
Can't link it cause its my first post. But searching ebay for the subject "MSF Radio Time Code Signal Atomic Clock Receiver" will bring it up.
What will i need to do to wire this up to the arduino? will i need to buy additional resistors? Im pretty much an electronics noob at this point, i know what a resister is, but im a bit fuzzy about "open drain" and "pullup resistors".
P1 (0v) Supply return and logic reference.
P2 (AGC-hold) connect to +supply to prevent AGC from reacting to external noise, leave unconnected when not required.
P3 (Out) Open drain data output signal, pulled to 0v when no carrier, high impedance (high) when carrier present.
P4 (+supply) e.g +5v ±½volt (note different voltage ranges possible).
P5 (Power-Down / Fast-Start) Receiver powered down if P5=0v (although on-board shunt regulator still active). When released (or driven to +supply) the fast start-up begins. Leave disconnected for 'auto fast start' to operate when board power is applied.
http://cgi.ebay.co.uk/MSF-Radio-Time-Code-Signal-Atomic-Clock-Receiver_W0QQitemZ260329204825QQihZ016QQcategoryZ72404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
is the link.
I wrote an arduino library that decodes radio time signals using the input capture capability of the Arduino chip. It decodes the DCF format which is slighlty different from MSF but the changes shouldbe minor. Let me know if this interests you and I will post it here.
Yeah that'd be awesome thanks!
No documentation so don't bother with this if you are looking for something that is plug and play. Also, I have not done the MSF conversion so you will need to read up on that to figure how it differs from the DCF signal.
there is a header file and a source file that need to be put in a directory alongside the other libraries called RadioTime.
Here is the is the header:
  RadioTime.h- Radio time code interface- Version 0.1
  DCF decode based on the Arduino DCF77 decoder v0.2 Copyright (C) 2006 Mathias Dalheimer (md@gonium.net)
  Input Capture support and modifications to a C++ class Copyright (c) 2008 Michael Margolis.  All right reserved.
// ensure this library description is only included once
#ifndef RadioTime_h
#define RadioTime_h
#include <inttypes.h>
typedef uint8_t byte;
typedef uint8_t boolean;
#define rxNO_SIGNAL -1
#define rxRESET      0
#define rxNEW_MINUTE 60
typedef enum {
       rxNoSignal,      // no signal received in last 4 seconds
     rxAcquiring,     // signal being received but time not yet fully decoded
       rxTimeValid,     // time data is valid and ready to use
       rxNewMinute      // this is the first service since the start of a new minute;
  } rxSignalState_t;
class RadioTime
private:      // User declarations
  // Clock variables
//  byte previousSecond;
  byte bufferPosition;  // was int !!
  unsigned long long dcf_rx_buffer;
  void ResetState();
  void processSignal(byte signal);
  boolean finalizeBuffer(void);
public:            // User declarations
  // time vars: the received time is stored here!
  char tzOffset;  // offset in hours to the current time zone (uk = -1)
  volatile byte second;
  volatile byte minute;
  volatile byte hour;
  volatile byte day;
  volatile byte dow; // day of week
  volatile byte month;
  volatile unsigned int year;
  RadioTime();
  void Init();
  void Init(byte pin); // initialise with radio signal mirrored on given pin
  char service(); // must be called at least twice a second, returns -1 if waiting for signal, else second count, 60 is new minute
#endif
edit: modifed to compile with version 0012
RadioTime.cpp
  RadioTime.cpp- Radio time code interface- Version 0.1
//#define DCF_DEBUG
#include <wiring.h>
#include <avr/interrupt.h>
#include "RadioTime.h"
// extern void debugOut(char* s, byte icrPulseCount, byte icrGapCount, byte bufferPosition);
#define icpPin 8        // ICP input pin on arduino
// Input capture uses Timer1, we prescale 16mhz clock by 1024 go give approx 16us tick
#define PRESCALE (_BV(CS12)| _BV(CS10))  // prescale = 1025, 1 tick = 64us
#define ICR1H_TIC   16   // number of milliseconds per each tic of the most significant byte of ICR counter)
// defines for pulse durations
#define DCF_PULSE0_MILLIS  100
#define DCF_PULSE1_MILLIS  200
#define DCF_BAD_SIG   ((DCF_PULSE0_MILLIS * 3) /4)   // pulse less than this are considered noise
#define DCF_BAD_SIG_THRESHOLD   (DCF_BAD_SIG/ICR1H_TIC)   // number of tics of TCNT1H for above period
#define DCF_PULSE1_THRESHOLD  (150/ICR1H_TIC)  // Halfway between the pulse durations
#define DCF_GAP_SECS_MILLIS 700 // gaps less then this are bad signal
#define DCF_GAP_SECS_COUNT    (DCF_GAP_SECS_MILLIS/ICR1H_TIC)   // tics of TCNT1H for minute gap
#define DCF_GAP_MIN_MILLIS 1700  // pulse greater than this is the minute marker gap)
#define DCF_GAP_MIN_COUNT    (DCF_GAP_MIN_MILLIS/ICR1H_TIC)   // tics of TCNT1H for minute gap
#define DCF_GAP_MAX_MILLIS 2000  // pulse greater than this are no signal)
#define DCF_GAP_MAX_COUNT      (DCF_GAP_MAX_MILLIS/ICR1H_TIC)   // tics of TCNT1H for minute gap
struct DCF77Buffer {
  unsigned long long prefix      :21;
  unsigned long long Min      :7;      // minutes
  unsigned long long P1            :1;      // parity minutes
  unsigned long long Hour      :6;      // hours
  unsigned long long P2            :1;      // parity hours
  unsigned long long Day      :6;      // day
  unsigned long long Weekday      :3;      // day of week
  unsigned long long Month      :5;      // month
  unsigned long long Year      :8;      // year (5 -> 2005)
  unsigned long long P3            :1;      // parity
struct DCFflags{
      unsigned char parity_flag      :1;
      unsigned char parity_min      :1;
      unsigned char parity_hour      :1;
      unsigned char parity_date      :1;
} flags;
// variables to store whats happening in the interrupt handlers
static volatile byte  icrPulseCount;
static volatile byte  icrGapCount;
static volatile boolean endOfMinute;
static char outPin;                //if >=0 then mirror signal changes on this pin
/* Overflow interrupt vector */
ISR(TIMER1_OVF_vect){                 // here if no input pulse detected after 4 seconds
  //rxState = rxNoSignal;
/* ICR interrupt vector */
ISR(TIMER1_CAPT_vect){
  TCNT1 = 0;                            // reset the counter
  if( bit_is_set(TCCR1B ,ICES1)){       // was rising edge detected ?
    icrPulseCount = ICR1/256;
      if( outPin >=0)
       digitalWrite(outPin,LOW );      // yes, set our output pin low to indicate end of pulse
  else {                                // falling edge was detected
    icrGapCount = ICR1/256;
      if(icrGapCount > DCF_GAP_MIN_COUNT)
         endOfMinute = true;
      if( outPin >=0)
       digitalWrite(outPin,HIGH );       // set our output pin high to blink at start of pulse
  TCCR1B ^= _BV(ICES1);                 // toggle bit value to trigger on the other edge
 RadioTime::RadioTime( )
  outPin = -1; // default value for pin disable output
void RadioTime::Init(byte pin)
   outPin = pin;   // todo check this works with an without given pin
   pinMode(outPin, OUTPUT);
   this->Init();
void RadioTime::Init()
  pinMode(icpPin, INPUT);                // ICP pin (digital pin 8 on arduino) as input
  endOfMinute = false;
  ResetState();
  icrPulseCount = icrGapCount = 0;
  second=minute=hour=day=dow=month=year=0;
  TCCR1A = 0 ;                    // this register set to 0!
  TCCR1B = PRESCALE ;    // NORMAL MODE!!, prescaller 1024, rising edge ICP1
  TCCR1B |= _BV(ICES1);           // enable input capture
  TIMSK1 =  _BV(ICIE1);                         // enable input capture interrupt for timer 1
  TIMSK1 |= _BV(TOIE1);                         // enable overflow interrupt to detect missing input pulses
void RadioTime::ResetState() {
      bufferPosition = 0;
      dcf_rx_buffer=0;
 * Append a signal to the dcf_rx_buffer. Argument is 0 or 1. An internal
 * counter shifts the writing position within the buffer. If position > 59,
 * a new minute begins -> time to call finalizeBuffer().
void RadioTime::processSignal(byte signal) {
    dcf_rx_buffer = dcf_rx_buffer | ((unsigned long long) signal << bufferPosition);
    // Update the parity bits. First: Reset when minute, hour or date starts.
    if (bufferPosition ==  21 || bufferPosition ==  29 || bufferPosition ==  36) {
      flags.parity_flag = 0;
    // save the parity when the corresponding segment ends
    if (bufferPosition ==  28) {
      flags.parity_min = flags.parity_flag;
    if (bufferPosition ==  35) {
      flags.parity_hour = flags.parity_flag;
    if (bufferPosition ==  58) {
      flags.parity_date = flags.parity_flag;
    // When we received a 1, toggle the parity flag
    if (signal == 1) {
      flags.parity_flag = flags.parity_flag ^ 1;
      //if( rxState == 0)
      //      rxState = rxAcquiring;  // flag returned in service routine to tell the app that we are receiving signals
    bufferPosition++;
#ifdef NEEDED
    if (bufferPosition > 59) {
        this->finalizeBuffer();
#endif
 * Evaluates the information stored in the buffer. This is where the DCF77
 * signal is decoded and the internal clock is updated.
void TimeZoneOffset(){
boolean RadioTime::finalizeBuffer(void) {
  boolean ret = false;  // default return code unless data validates ok
  if (bufferPosition == 59) {
    struct DCF77Buffer *rx_buffer;
    rx_buffer = (struct DCF77Buffer *)(unsigned long long)&dcf_rx_buffer;
    if (flags.parity_min == rx_buffer->P1  &&
        flags.parity_hour == rx_buffer->P2  &&
        flags.parity_date == rx_buffer->P3 )
      //convert the received bits from BCD
      minute = rx_buffer->Min-((rx_buffer->Min/16)*6);
      hour = rx_buffer->Hour-((rx_buffer->Hour/16)*6);
      day= rx_buffer->Day-((rx_buffer->Day/16)*6);
      dow= rx_buffer->Weekday-((rx_buffer->Weekday/16)*6);
      month= rx_buffer->Month-((rx_buffer->Month/16)*6);
      year= 2000 + rx_buffer->Year-((rx_buffer->Year/16)*6);
      TimeZoneOffset(); // add or subtract time zone offset
        ret = true;  // data is valid
  // reset stuff
  second = 0;
  bufferPosition = 0;
  dcf_rx_buffer=0;
  return ret;
 * Dump the time to the serial line.
#ifdef NEEDED
void serialDumpTime(void){
  Serial.println("");
  Serial.print("Time: ");
  hour -=1;   // correct for UK time if using DCF
  if( hour == 0)  // TODO need to check for correct day month & year!!!!
     hour = 23;
  Serial.print(hour, DEC);
  Serial.print(":");
  if(minute < 10)
     Serial.print("0");
  Serial.print(minute, DEC);
  Serial.print(":");
  if(ss < 10)
     Serial.print("0");
  Serial.print(second, DEC);
    Serial.print(" Day of week: ");
  Serial.print(dow, DEC);
  Serial.print(" Date: ");
  Serial.print(day, DEC);
  Serial.print(".");
  Serial.print(month, DEC);
  Serial.print(".");
  Serial.println(year, DEC);
#endif
char RadioTime::service(){  // returns second count , -1 if signal, 0 if reset by next minute signal
  char ret;
  if( bufferPosition < 59)
     ret = bufferPosition+ 1;  // don't return 60 until minute signal received
    ret = bufferPosition;
  if( icrPulseCount > 0){
        if( icrPulseCount < DCF_BAD_SIG_THRESHOLD ){
         //debugOut("bad sig ", icrPulseCount, icrGapCount,bufferPosition);
            // debugOut("thresholds: ", DCF_BAD_SIG_THRESHOLD,  DCF_GAP_MIN_COUNT,  DCF_GAP_MAX_COUNT );
         ResetState();
             ret = rxNO_SIGNAL;
        else{
          unsigned char signal = icrPulseCount > DCF_PULSE1_THRESHOLD ? 1: 0;   // signal is 0 if duration is less than count (~150ms)
          processSignal(signal);
        icrPulseCount = 0;  // reset the count ready for the next signal
  if(endOfMinute ){
        // end of minute
         icrGapCount = 0;  // reset the count ready for the next signal
       if(bufferPosition == 59) {
          if( finalizeBuffer())
                 ret = rxNEW_MINUTE; // this indicates new minute
              ret = rxRESET; // finalize did not validate the data
        else {
               ResetState();
               ret = rxRESET;
   return ret;
I don't have a test sketch, this went straight into an application, but the code below should get you going. Its untested so may need tweeking.
I am having second thoughts about posting all this, the code is running a clock sitting on my desk but its been a while since I looked at it. You may need to do some work to get all this stuff going but I hope it will be easier than starting from scratch.
#include <RadioTime.h>
RadioTime MSF = RadioTime();
void setup(){
   MSF.Init(13); // flash LED on pin 13 to show input pulses
void loop(){
  static int secs, oldsecs;
   secs = MSF.service();
   if(secs == rxNO_SIGNAL){
      Serial.print("Waiting for signal ");
      while( MSF.service() == rxNO_SIGNAL)   // wait here for a signal
         delay(100);
   else if(secs != oldsecs ){
      Serial.print(MSF.hour);
      Serial.print(":");
      Serial.print(MSF.minute);
      Serial.print(":");
      Serial.println(MSF.second);
Thats awesome thanks, ive been reading the MSF signal protocol on wikipedia, and ill have a play tonight.
I found your page with the circuit diagram (i think its your site) as well, which is what i originally came here to ask about.
Thats not my site, the information on http://gonium.net/md/2006/11/05/arduino-dcf77-radio-clock-receiver/comment-page-1/#comment-2389 was the basis for the library posted and credit for the original work belongs to Mathias Dalheimer
Does anyone have lately tried this code? I can't get it working, nor the mem code nor the one on "gomiun" website. With this code, from the playground, I get only an infinite " ; ; " on my console...
Using pin 8 (reading the class)
