// Example 48.1 - tronixstuff.com/tutorials > chapter 48 - 30 Jan 2013
// MSGEQ7 spectrum analyser shield - basic demonstration
int strobe = 4; // strobe pins on digital 4
int res = 5; // reset pins on digital 5
int left[7]; // store band values in these arrays
int right[7];
int band;
pinMode(res, OUTPUT); // reset
pinMode(strobe, OUTPUT); // strobe
digitalWrite(res,LOW); // reset low
digitalWrite(strobe,HIGH); //pin 5 is RESET on the shield
void readMSGEQ7()
// Function to read 7 band equalizers
digitalWrite(res, HIGH);
digitalWrite(res, LOW);
for(band=0; band <7; band++)
digitalWrite(strobe,LOW); // strobe pin on the shield - kicks the IC up to the next band
delayMicroseconds(30); //
left[band] = analogRead(0); // store left band reading
right[band] = analogRead(1); // ... and the right
readMSGEQ7();
// display values of left channel on serial monitor
for (band = 0; band < 7; band++)
Serial.print(left[band]);
Serial.print(" ");
// display values of right channel on serial monitor
Serial.print(right[band]);
Serial.print(" ");
could some one please help by showing me in very simple terms or modified this for me if its ok to get a drawing or something of the output pins on each one of the 14 out puts so I can have lots of lights and maybe a schematic to help show how to hook it up I am pretty good at the hardware but don’t know how to code and would like to play with this to help me understand better of what is going on and can I output to 595 shift registers and if yes then a little help on how to hook them up and the code please
thank you for any help
and please keep it as simple as possible I am just learning and don’t really know much about code
