MSGEQ7 with LCD 20x4 I2C
Hello everyone I read this link
The original link of it is this; link, my intention is to adapt my LCD 20x4 with I2C bus
I use this library Malpartida
All right. I managed to go down to the second and third column the spectrum but want to have all the lcd, but modified and it does not work.
Pictures;
This is the modified my code;
#include <Wire.h>
#define I2C_ADDR    0x3f // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
byte vumetro[8][8];
float vumetros[16];
// The analog pin 0 is used to read value.
int valor_analogico = 0;
// The 6 & 7 pins are used for control the integrated.
int strobe = 4;
int reset = 5;
int valores_frecuencias[7];
        lcd.begin(20, 4);
        lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
        lcd.setBacklight(HIGH);
  // Built the characters for bars.
  for (int j=0; j<=7; j++)
    for (int i=0; i<=7; i++)
       for (int h=0; h<=7; h++)
        for (int z=0; z<=7; z++)
      if (i<=j)
      { vumetro[j][7-i] = B11111;} // B01110
//   { vumetro[j][i][h][7-z] = B11111;}
//      { vumetro[j][7-i] = B01010;}  Uncomment this lines for getting other variants for bars.
//      { vumetro[j][7-i] = B11111;}
      { vumetro[j][7-i] = 0;}
//        { vumetro[j][i][h][7-z] = 0;}
  for (int i=0; i<=7;i++)
    lcd.createChar(i, vumetro[i]);
  for (int j=0; j<=7;j++)
    lcd.setCursor(j, 0);
    lcd.write(j);
    lcd.setCursor(j, 1);
    lcd.write(j);
    lcd.setCursor(j, 2);
    lcd.write(j);
    lcd.setCursor(j, 3);
    lcd.write(7);
  pinMode(valor_analogico, INPUT);
  pinMode(strobe, OUTPUT);
  pinMode(reset, OUTPUT);
  analogReference(DEFAULT);
  digitalWrite(reset, LOW);
  digitalWrite(strobe, HIGH);
  digitalWrite(reset, HIGH);
  // The read of integrated is done by multiplexing.
  for (int i = 0; i < 7; i++)
    digitalWrite(strobe, LOW);
    delayMicroseconds(5);
    valores_frecuencias[i] = analogRead(valor_analogico);
// It's necesary to interpolate for calculating 16 bars having only 7 values read.
for (int k=0; k<=15; k++)
  switch (k)
    case 0:
      vumetros[k]= valores_frecuencias[0]/64;
    case 1:
      vumetros[k]= (valores_frecuencias[0]/64 + valores_frecuencias[1]/64)/2;
    case 2:
      vumetros[k]= valores_frecuencias[1]/64;
    case 3:
      vumetros[k]= (valores_frecuencias[1]/64 + valores_frecuencias[2]/64)/2;
    case 4:
      vumetros[k]= valores_frecuencias[2]/64;
    case 5:
      vumetros[k]= (valores_frecuencias[1]/64 + valores_frecuencias[2]/64 + valores_frecuencias[3]/64)/3;
    case 6:
      vumetros[k]= (valores_frecuencias[2]/64 + valores_frecuencias[3]/64 + valores_frecuencias[4]/64)/3;
    case 7:
      vumetros[k]= random(2)+valores_frecuencias[3]/64;
    case 8:
    case 9:
    case 10:
      vumetros[k]= (valores_frecuencias[3]/64 + valores_frecuencias[4]/64 + valores_frecuencias[5]/64)/3;
    case 11:
      vumetros[k]= valores_frecuencias[4]/64;
    case 12:
      vumetros[k]= (valores_frecuencias[4]/64 + valores_frecuencias[5]/64)/2;
    case 13:
      vumetros[k]= valores_frecuencias[5]/64;
    case 14:
      vumetros[k]= (valores_frecuencias[5]/64 + valores_frecuencias[6]/64)/2;
    case 15:
      vumetros[k]= valores_frecuencias[6]/64;
  Dibuja_vumetro(k, vumetros[k]);
  delay(2);
 void Dibuja_vumetro(int posicion, int altura)
  if (altura>7)
    if (altura>14)
      if (altura>21)
        lcd.setCursor(posicion, 3);
        lcd.write(7);
        lcd.setCursor(posicion, 2);
        lcd.write(7);
        lcd.setCursor(posicion, 1);
        lcd.write(7);
        lcd.setCursor(posicion, 0);
        lcd.write(altura-8);
      lcd.write(7);
      lcd.write(7);
      lcd.write(32);
    lcd.write(7);  //tutto acceso
    lcd.write(32);
    lcd.write(32);
    lcd.write(altura);
    lcd.write(32);   //tutto spento
    lcd.write(32);
    lcd.write(32);
How to correct the code to see the entire screen?
I can please help? Thanks for your answers.
I've not looked at the code in detail, but it really looks like you need a case 15,19 to cover the last 4 rows (or columns depending on how you hold the screen.
Thank you. But what I try is to put the spectrum in the ranks 0, 1, 2, 3 , columns 15 to 19 is not a problem I do not get put in all rows. Regards
OK, three points.
  • What is your native language? If English, then it might be nice to use the Edit (-> Find) function in the IDE to translate the code into English.
  • You suggest that the first two rows are not working, but the display you illustrate simply does not contain values that approach this area.
  • You have to add the interpolation code for the additional columns. If English is indeed your language, it would be a little easier to translate it first. :grinning:
Sorry my bad English language is Spanish. I'm trying unsuccessfully to do this same ;
https://www.youtube.com/watch?v=VZtVF96jFY8
