MsTimer2 question
I’m using 328p and IDE 018.
The LED (13) should blink at start and only once again after 5 seconds.
But the LED does not switch off after 5 sec.
What’s wrong with this code ?
// blink once on start and once after 5 sec
#include <MsTimer2.h>
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
  flash();
  MsTimer2::set(5000, flash);
  MsTimer2::start();
void flash() {
  digitalWrite(13, HIGH);
  MsTimer2::stop();
delay(500) only works if timer0-interrupts are allowed to advance the millisecond-counter. The second call to flash is made from a timer2-interrupt, which blocks other interrupts so it will hang forever in delay(500).
Thank You ! Would this wotk if i disable only timer2-interrupt ?
not good idea, i assume. any suggestion ?
disabling timer2 interrupt is what MsTimer2::stop() does.
What you could do is have the function you specify in MsTimer2::set() only set a global (and volatile) flag to true. Then you could use, e.g.
    if (flag) {
      flag = false;
      // possibly call MsTimer2::stop() here if the flash is only to be run once
ok, thx :)
