Multi-analog output value smoothing function
Hey,
I've tried changing the variables from 'int' to 'unsigned int' and 'long' and there is no visible difference all outputs are identical. The results show the value of var average which I want to print to serial and use as a value of luminosity for my led. See the serial results here:
-28
-28
-29
-27
-30
-27
-28
-30
-30
-30
-30
-29
-30
-30
-30
-30
-30
-26
-28
(this is where I shined a torch at the LDR)
29
29
-11
-10
1
21
27
26
23
20
27
25
22
22
(this is where I took the tortch away)
-13
-13
2
-29
-28
-30
-28
-27
-30
I spammed the Serial.println() function in order to see whats inside each variable each loop and the results may explain the calculated negative numbers. Here are the results (key below):
Start total: 0
Start index: 0
RAW: 30
Output average: 0
Start total: 0
Start index: 0
RAW: 30
Output average: 0
Start total: 0
Start index: 0
RAW: 30
Output average: 0
Start total: 0
Start index: 0
RAW: 30
Output average: 0
Start total: 0
Start index: 0
RAW: 30
Output average: 0
Key:
Start total = the value of var total at the start of each loop
Start index = the value of var 'readIndex' at the start of each loop (should be progressing to 10 and resetting to 0, rinse and repeat)
RAW = the value outputted from the sensor
Output average = the value I want to display
My program isn't passing the data like it should be. Maybe returning multiple variables isn't ideal?
