multi button array not clear on where to detect a particular button pin
Hello All,
Found this sketch, I am trying to learn arrays using multiple buttons.
After studying this code I can’t seem to find a way to isolate a particular button release. I set this up using 2 buttons, pin 2 and pin 3 pull down.
When I press either button 2 or 3 they both do the same thing turn on or off led 7.
Where in the code can I isolate a button release from just a particular button pin, like say pin 2
Thanks for any help
#define DEBOUNCE 20  // button debouncer, how many ms to debounce, 5+ ms is usually plenty
// here is where we define the buttons that we'll use. button "1" is the first, button "6" is the 6th, etc
//byte buttons[] = {4, 9, 12, A0}; // the analog 0-5 pins are also known as 14-19
//my edit
byte buttons[] = {2, 3,}; // the analog 0-5 pins are also known as 14-19
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// we will track if a button is just pressed, just released, or 'currently pressed'
volatile byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
  byte i;
  // set up serial port
  Serial.print("Button checker with ");
  Serial.print(NUMBUTTONS, DEC);
  Serial.println(" buttons");
  // pin13 LED
  pinMode(13, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  // Make input & enable pull-up resistors on switch pins
  for (i=0; i < NUMBUTTONS; i++)
  { pinMode(buttons[i], INPUT_PULLUP);
    digitalWrite(buttons[i], HIGH);
  // Run timer2 interrupt every 15 ms
  TCCR2A = 0;
  TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1<<TOIE2;
SIGNAL(TIMER2_OVF_vect) {
  check_switches();
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  static long lasttime;
  byte index;
  if (millis() < lasttime){ // we wrapped around, lets just try again
     lasttime = millis();
  if ((lasttime + DEBOUNCE) > millis()) {
    // not enough time has passed to debounce
    return;
  // ok we have waited DEBOUNCE milliseconds, lets reset the timer
  for (index = 0; index < NUMBUTTONS; index++){
    currentstate[index] = digitalRead(buttons[index]);   // read the button
    Serial.print(index, DEC);
    Serial.print(": cstate=");
    Serial.print(currentstate[index], DEC);
    Serial.print(", pstate=");
    Serial.print(previousstate[index], DEC);
    Serial.print(", press=");
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
          // just pressed
          justpressed[index] = 1;
          //my add
          digitalWrite(7, LOW);
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
          // just released
          justreleased[index] = 1;
          //my add
          digitalWrite(7, HIGH);
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
    //Serial.println(pressed[index], DEC);
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
  for (byte i = 0; i < NUMBUTTONS; i++){
    if (justpressed[i]) {
      justpressed[i] = 0;
      Serial.print(i, DEC);
      Serial.println(" Just pressed");
      // remember, check_switches() will CLEAR the 'just pressed' flag
    if (justreleased[i]) {
      justreleased[i] = 0;
      Serial.println(" Just released");
    if (pressed[i]) {
      Serial.println(" pressed");
      // is the button pressed down at this moment
using interrupts to monitor buttons is overkill and complicated.
Serial.prints inside an interrupt is just poor practice and defeats the purpose of using an interrupt to immediately capture a hardware event.
interrupts typically blindly capture events, possibly timestamps (micros()) and leave it to code invoked in loop() to deal with the event unless there needs to be a real-time response
here’s a simpler approach for monitoring multiple buttons that is less intrusive for other code that may require interrupts or better real-time performance
// recognize multiple button presses; tgl LED when pressed
#define ON  LOW
#define OFF HIGH
byte butPins [] = { A1, A2, A3 };
byte ledPins [] = { 10, 11, 12 };
#define N_PINS sizeof(butPins)
byte butLst [N_PINS] = {};
void setup (void)
    for (unsigned n = 0; n < N_PINS; n++)  {
        digitalWrite (ledPins [n], OFF);
        pinMode      (ledPins [n], OUTPUT);
        pinMode      (butPins [n], INPUT_PULLUP);
        butLst [n]  = digitalRead (butPins [n]);
void loop (void)
        byte but = digitalRead (butPins [n]);
        if (butLst [n] != but)  {
            butLst [n] = but;
            if (LOW == but)     // button pressed
                digitalWrite (ledPins [n], ! digitalRead (ledPins [n]));
    delay (10);         // debounce
Thank you for your reply, but I am just trying to see how other types of code that I find works.
