Multi Chaser with Millis On/Off Switch help
Newbie here so don't crucify me please!
Using an Arduino Nano.
I have looked, read and studied a lot of code and this is what I have thus far. It works for what I would like but, there are a few things I want to add, however, not sure how to do it, thus I am asking for some input/help.
Key thing I would like to do, is to be able to make the MainChaser (scanner lights) to be controlled by a On/Off button. I can not seem to quite figure that out.
The other is that I would like to have a secondary button simply turn an LED on and off. No delays or millis, just plain on or off.
I have pins 2, 9 and 13 still available for all of this.
Any help is appreciated.
Here is what I have:
const int MainChaser[] = {
  6,5,4,3};  // front scanner center out
const int Chaser_Count = sizeof MainChaser / sizeof (int);
const int ChaserIntervals[] =
  140, 140, 140, 140}
;  // Milliseconds
unsigned long ChaserTime = millis();
int ChaserStep = 0;
const int Library[] = {
  10,11,12};  //alpha , beta, gamma, delta
const int Library_Count = sizeof Library / sizeof (int);
const int Library_Intervals[] = {
  400, 400, 400}
;  // Milliseconds
unsigned long LibraryTime = millis();
int LibraryStep = 0;
const int Temp[] = {
  7,8};  //front two above scanner
const int Temp_Count = sizeof Temp / sizeof (int);
const int Temp_Intervals[] = {
  1000, 1000}
;  // Milliseconds
unsigned long TempTime = millis();
int TempStep = 0;
  int i;
  /* Chaser LED's */
  for (i=0; i< Chaser_Count; i++)
    pinMode(MainChaser[i], OUTPUT);  // Yes, it's OK to set the pinMode twice on some pins
  /* Library LED's */
  for (i=0; i< Library_Count; i++)
    pinMode(Library[i], OUTPUT);
      /* Temp LED's */
  for (i=0; i< Temp_Count; i++)
    pinMode(Temp[i], OUTPUT);
  // Do the chaser animation - front scanner
  if ((millis() - ChaserTime) > ChaserIntervals[ChaserStep])
    digitalWrite(MainChaser[ChaserStep], LOW);
    ChaserStep = (ChaserStep+1) % Chaser_Count;
    digitalWrite(MainChaser[ChaserStep], HIGH);
  // Do the library animation  - alpha , beta, gamma, delta
  if ((millis() - LibraryTime) > Library_Intervals[LibraryStep])
    digitalWrite(Library[LibraryStep], LOW);
    LibraryStep = (LibraryStep+1) % Library_Count;
    digitalWrite(Library[LibraryStep], HIGH);
 // Do the Temp animation
  if ((millis() - TempTime) > Temp_Intervals[TempStep])
    digitalWrite(Temp[TempStep], LOW);
    TempStep = (TempStep+1) % Temp_Count;
    digitalWrite(Temp[TempStep], HIGH);
Until now all output loops run unconditionally. Add another if statement that checks the button and then either runs the animation code or turns all lights off.
Thanks, I will gave that a try again.
