HI
On the screen I can draw different colors lines by switching the case number, each case starts with blank blue screen. How to make drawing lines in different colors on the same screen withouth erasing previois lines ?
this is what I have
this is what I need
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h>
#include <SPI.h>
#define TFT_MOSI 23 // Data out
#define TFT_SCLK 18 // Clock out
#define TFT_CS 22// // Chip select pin
#define TFT_DC 21 // Data/Command pin
#define TFT_RST -1 // pin# 2
// Create an instance of the display driver
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
int DCX1, DCX2, DCY1, DCY2;
byte lastButtonState = LOW;
int botonState = 0;
tft.init(170, 320);
tft.setRotation(3); // Adjust rotation as needed (0-3),0 = viertical, 1= horyzontal upside down, 2= viertical 180 deg , 3=horyzontal normal,
// Clear the screen
//tft.fillScreen(ST77XX_BLACK);//++++++++++++++++++++++++++++++++
tft.fillScreen(ST77XX_BLUE);
tft.setTextWrap(false); // Disable text wrapping
tft.setTextSize(4); // Set text size
// tft.setTextColor(ST77XX_WHITE); // Set text color +++++++++++++++++++
tft.setTextColor(ST77XX_YELLOW); // Set text color
DCX1 = analogRead(39);
//DCX1 = map(DCX1, 0, 4096, 0, 3300);
DCX1 = map(DCX1, 0, 4096, 0, 1600);
// DCX1 = DCXp(DCX1, 0, 4096, 0, 500);
//DCX2 = 3299 - DCX1;
DCX2 = 1600 - DCX1;
DCY1 = analogRead(36);
//DCY1 = analogRead(39);
// DCY1 = map(DCY1, 0, 4096, 0, 3300);
DCY1 = map(DCY1, 0, 4096, 0, 1600);
DCY2 = 3299 - DCY1;
DCY2 = 1600 - DCY1;
// tft.setCursor(10, 50); // Set cursor position (x, y)
// tft.print("Hello World!");
Serial.println( "Hello World");
if (digitalRead(2) == 0)
// botonState = (botonState + 1) % 4;
botonState = (botonState + 1) % 7;
delay (200);
switch (botonState)
case 0:
tft.setCursor(10, 0); // Set cursor position (x, y)
tft.print("0");
tft.fillRect(150 + (DCX1 / 23), 150 - (DCY1 / 23), 3 , 3, ST77XX_WHITE);
case 1:
tft.print("1");
tft.fillRect(150 + (DCX1 / 23), 150 - (DCY1 / 23), 3 , 3, ST77XX_GREEN);
case 2:
tft.print("2");
tft.fillRect(150 + (DCX1 / 23), 150 - (DCY1 / 23), 3 , 3, ST77XX_RED);
case 3:
tft.print("3");
case 4:
tft.print("4");
tft.fillRect(150 + (DCX1 / 23), 150 - (DCY1 / 23), 3 , 3, ST77XX_BLACK);
case 5:
tft.print("5");
case 6:
tft.print("6");
