Multi Click Button w/ RGB LED and Standard LED
Hello!
Its morgofryxx here and well, guys i hate to admit it, but Im stuck. In fact I have been stuck on this segment of code for almost 3 weeks now with no major breakthrough. I am trying to create a program that will enable a multi click function for a button turning on an RGB LED (which I got from adafruit) and then after a delay of a few seconds will turn it off. Then after the RGB LED is turned off, a delay of a few more seconds follows after which a standard led is turned on for a bit and then off. As soon as I can receive some guidance here the better. This is really important since it is for school and I have a deadline... Please respond ASAP!!
I used the tutorial on statechange detection from the arduino website and followed a guide on rgb leds that I found on a different website... Anyway...
The code that I have been using for the program is as follows (without the 2 lines of ////// obviously, they are just there to separate the description from code lol) :
const int buttonPin = A1; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
// Variables will change:
int PushCounter = 0;
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int redPin = 6;
int greenPin = 5;
int bluePin = 7;
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
pinMode(motorPin, OUTPUT);
// initialize serial communication:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
if (buttonState == HIGH) {
PushCounter++;
Serial.println("on");
Serial.print("number of pushes: ");
Serial.println(PushCounter);
else {
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
delay(50);
lastButtonState = buttonState;
if (PushCounter == 1) {
setColor(255,0,0);
delay(2000);
setColor(0,0,0);
delay(2000);
digitalWrite(motorPin, HIGH);
delay(2000);
digitalWrite(motorPin, LOW);
else if (PushCounter == 2) {
setColor(0,255,0);
delay(2000);
setColor(0,0,0);
delay(2000);
delay(2000);
else if (PushCounter == 3) {
setColor(0,80,8);
delay(2000);
setColor(0,0,0);
delay(2000);
delay(2000);
else {
setColor(0,0,0);
void setColor(int red, int green, int blue)
#ifdef COMMON_ANODE
red = 255 - red;
green = 255 - green;
blue = 255 - blue;
#endif
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
The code you posted incorrectly does something. You expect it to do something. All that we know at this point is that the two somethings are not the same thing.
Read the stickies at the top of the forum, to learn how to post code correctly, and edit your initial post.
