Multi-dimensional Array Declaration using existing Arrays?
Hi, is it possible to declare a multi-dimensional array from existing arrays like the following:
(I know the following doesn't work).
//Colors
int red[] = {255,0,0};
int green[] = {0,255,0};
int blue[] = {0,0,255};
int pink[] = {255,0,128};
int yellow[] = {255,255,0};
int aqua[] = {0,255,255};
//Palette
int palette[][] = {red, green, blue, pink, yellow, aqua};
//using the palette for something....
for (i=0; i<5: i++) {
    color = CRGB(palette[i][0],palette[i][1],palette[i][2]);
I know I can make an array of arrays "manually" like this:
int palette[][3] = {{255,0,0},{0,255,0},{0,0,255}};
But wondered if it could be done with existing arrays, too.
Thanks for the help!
J
(I just realized I posted this in the wrong section, I meant to put it in Syntax... I don't see how I cam move it :-()
I am not sure what exactly you are trying to do.
No, you cannot use the name of an array to initialize another array.
To hold related values (like red, green, blue colour components) that comprise a larger unit (a colour) you would normally use a struct.
Here is some 3 way example code that might answer your question:
// Using a struct for the colour components
struct Colour {
  byte r;
  byte g;
  byte b;
Colour redColour{255, 0, 0};
Colour greenColour{0, 255, 0};
Colour paletteOfColours[] = { redColour, greenColour }; // copies elements into new array memory, duplication == waste of RAM
Colour *paletteOfColourPtrs[] = { &redColour, &greenColour }; // array of pointers to  previously declared Colour's, no duplication, more complicated syntax
void printColour(Colour c) {
  Serial.print("(");
  Serial.print(c.r); Serial.print(",");
  Serial.print(c.g); Serial.print(",");
  Serial.print(c.b);
  Serial.print(")");
// Using an array for the colour components
int red[] = {255, 0, 0};
int green[] = {0, 255, 0};
int blue[] = {0, 0, 255};
int pink[] = {255, 0, 128};
int yellow[] = {255, 255, 0};
int aqua[] = {0, 255, 255};
int *palette[] = {red, green, blue, pink, yellow, aqua}; // don't need the & operator since an array will automatically convert to a pointer when required
void printTriplets(int *triplet) {
  Serial.print("(");
  Serial.print(triplet[0]); Serial.print(",");
  Serial.print(triplet[1]); Serial.print(",");
  Serial.print(triplet[2]);
  Serial.print(")");
// Test stuff
  Serial.println("paletteOfColours:");
  for (unsigned i = 0; i < sizeof(paletteOfColours) / sizeof(paletteOfColours[0]); i++) {
    printColour(paletteOfColours[i]);
  Serial.println("paletteOfColourPtrs:");
  for (unsigned i = 0; i < sizeof(paletteOfColourPtrs) / sizeof(paletteOfColourPtrs[0]); i++) {
    printColour(*paletteOfColourPtrs[i]);
  Serial.println("palette:");
  for (unsigned i = 0; i < sizeof(palette) / sizeof(palette[0]); i++) {
    printTriplets(palette[i]);
void loop() { }
PS: To have a thread moved to a different forum section just click "Report to moderator" and fill in your request.
Arrays of references (&) or pointers (*) can be used to construct arrays based on existing arrays.
References instead of pointers will remove the need for pointer dereferencing in the code.
DrDiettrich:
Arrays of references (&) ... can be used to construct arrays based on existing arrays.
You sure about that?
You aren't?
To my knowledge, there are no arrays of references in C++.
Thank you all for your replies...
ieee488 - I have a project on which I have some controllable LED Strips... Previously, I had created a few lines of arrays with the different colors (the list that I showed in my example). I have a few assemblies of these and wanted each one to light in a different color. Instead of re-writing all of my code for each one, I used the same code for each one, which included all the color arrays and just manually changed the one line in the Fastled section for the color I wanted before uploading to the board.
eg. CRGB(red[0],red[1],red[2]) for the first unit, CRGB(blue[0],blue[1],blue[3]) for the second and so on.
I decided to "upgrade" my project, adding a color-change button to each unit. In my example above, I used a for-loop to demonstrate cycling through the elements from the palette array, but in practice, I have it so every time you press the button, it advances the "palette array" by one to select the color. - I just figured the "for loop" would be less to type in the forum.
Essentially, I was asking the question about putting the "arrays of colors" inside the "palette array" out of curiosity. Originally I figured I could just re-use my existing code by storing the existing color arrays inside of the palette array but saw that it didn't work. I know I've nested arrays like this in other languages (whether or not it is a waste of resources is debatable, of course) but when I couldn't get it to work here, I wondered if it was something I was doing wrong, or just something that couldn't be done.
arduarn - Thank you for the information on structs and pointers... I am familiar with the concept of pointers, but have only used them in one other project. I was under the impression that the use of pointers is for saving resources - It didn't occur to me to even try them.
Same for structs. I am (clearly) not that advanced of a programmer, so though I know what a Structure is, I didn't know what would make it different from an Array in the sense of how it would behave differently than an array.
Just so I understand (or perhaps to point out that I don't :-)) - you are saying that had I used STRUCTS instead of Arrays to define my colors, the structs can be stored in another array? (Or pointed to as you show?)
I am not entirely sure why the Struct behaves differently than an Array (with respect to being nested inside of another array) but I am reading about it now - looks like it has to do with how Arrays are pointers to the beginning of memory locations and Structs are clearly defined memory locations. (am I on the right track here?)
Thank you again for the assistance!
J
roboscan:
Yes.
roboscan:
After writing a paragraph of text and realising that it was totally confusing crap, I'll just link to something (c-faq.com) which is hopefully a bit clearer. See some of the other related FAQs too.
