macnl
November 8, 2021, 8:05pm
1
I made this test program..
const PROGMEM byte prog[2][25] ={
{0,1,2,3,99},
{1,2}
}; //5 programmas met 23 aantal stappen 99 is einde
byte x=0;
byte i=0;
for (i = 0; i <5; i++)
x=prog[0][i];
Serial.print (i);
Serial.print (" ");
Serial.println(x);
delay(5000);
if i write x=prog[0][4]; it returns 99 (what you would expect)
But if i use the variable i (witch is 0,1,2,3,4) it doesent work!&#$ &^
Im doing something wrong??
I also tried to avoid serial print (while that give sometimes problems) but that also doesent help.
Here's a ref guide for you: PROGMEM - Arduino Reference
And a working example.
const byte prog[2][2] PROGMEM = { {1, 2}, {3, 4} };
for (int i = 0; i < 2; i++) {
for (int j = 0; j < 2; j++) {
Serial.print(F("prog["));
Serial.print(i);
Serial.print(F("]["));
Serial.print(j);
Serial.print(F("] = "));
Serial.println(pgm_read_byte_near(&prog[i][j]));
void loop() { }
macnl
November 8, 2021, 8:55pm
3
Ah.. its about the adress pointer
Thanx
No, it's about the pgm_read_byte
Please remember to use code tags when posting code
In this case the compiler does the work because you only use constants. The compiler knows, that prog[0][4] is 99, inserts that directly and compiles it to x=99;
If you use variables as index this is not possible and the array must be accessed at runtime. Because the AVR processors need special commands to read data from PROGMEM you must advise the compiler to do so. This is done by the pgm_read... functions.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
See also FAQ - Arduino Forum for general rules on forum behaviour and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is fru…
system
Closed
May 8, 2022, 9:03am
7
