Maybe you can elaborate what "wrong code" means. If I replace X by 5, the code happily compiles.
If you really want the first dimension to be of different sizes, you first need to define a number of arrays like
int pin1[] = {1, 1};
int pin2[] = {2, 2, 2, 2, 2};
int pin3[] = {3, 3};
and next you can use an array of pointers
int *pinMatrix[]=
pin1,
pin2,
pin3,
This however brings another problem; in pinMatrix you can't determine the size of the individual arrays. So a two-dimensional iteration is doomed to fail.
To solve that, you can use an array of structs; the struct combines a pointer to the pinX with the number of elements in pinX.
struct PINS
int *pins;
uint16_t numElements;
PINS pinMatrix[] =
{pin1, sizeof(pin1) / sizeof(pin1[0])},
{pin2, sizeof(pin2) / sizeof(pin2[0])},
{pin3, sizeof(pin3) / sizeof(pin3[0])},
Instead of typing stuff like sizeof(pin1) / sizeof(pin1[0]) all the time, you can define a macro and place it at the top of the code
#define NUMELEMENTS(x) (sizeof(x) / sizeof(x[0]))
The below code demonstrates how to iterate the two dimensions
int pin1[] = {1, 2};
int pin2[] = {9, 8, 7, 6, 5};
int pin3[] = {3, 4};
struct PINS
int *pins;
PINS pinMatrix[] =
{pin1, NUMELEMENTS(pin1)},
{pin2, NUMELEMENTS(pin2)},
{pin3, NUMELEMENTS(pin3)},
Serial.begin(57600);
Serial.print("number of rows in pinMatrix = "); Serial.println(NUMELEMENTS(pinMatrix));
for (uint16_t rowCnt = 0; rowCnt < NUMELEMENTS(pinMatrix); rowCnt++)
Serial.print("number of columns in pinMatrix["); Serial.print(rowCnt);
Serial.print("] = "); Serial.println(pinMatrix[rowCnt].numElements);
Serial.print("content = ");
for (uint16_t colCnt = 0; colCnt < pinMatrix[rowCnt].numElements; colCnt++)
Serial.print(pinMatrix[rowCnt].pins[colCnt]); Serial.print(", ");
