Hello, I'm trying to write a program to control a small (4x4) LED matrix for a wearable electronics project using Leah Buchley's Lilypad arduino (http://www.cs.colorado.edu/~buechley/LilyPad/index.html)
I'm having some trouble with my code:
const int size = 4; //4x4 LED array
const int rows[size] = {1, 2, 3, 4}; //rows to pin mapping
const int cols[size] = {5, 6, 7, 8}; //cols to pin mapping
const int numPatterns = 2; //Number of patterns programmed in
boolean patterns[numPatterns][size][size];
int time;
void setup() { // run once, when the sketch starts
for (int i = 0; i < size; i++) {
pinMode(rows[i], OUTPUT);
pinMode(cols[i], OUTPUT);
//Patterns
patterns[0] = {
{1, 1, 1, 1},
{1, 1, 1, 1},
{1, 1, 1, 1},
{1, 1, 1, 1}
patterns[1] = {
{0, 0, 0, 0},
{0, 0, 0, 0},
{0, 0, 0, 0},
{0, 0, 0, 0}
time = 1; //start time at 1 so as not to skip first pattern
void loop() { // run over and over again
time = millis()%1000;
int currPattern = 0;
while (currPattern < numPatterns) {
for (int currRow = 0; currRow < size; currRow++) {
runRow(currRow, currPattern);
if (time == 0) {
currPattern++;
void runRow(int currRow, int currPattern) {
digitalWrite(rows[currRow], HIGH); //Assert row to allow LEDs in it to turn on
for (int col = 0; col < size; col++) {
if (patterns[currPattern][currRow][col]) {
digitalWrite(cols[col], LOW); //Deassert column to turn on LED
else {
digitalWrite(cols[col], HIGH); //Keep column high to turn off LED
digitalWrite(rows[currRow], LOW); //Deassert row to prepare for next row run
The goal is to cycle through a fixed number of pre-programmed patterns, defined in the "setup" function. Every second ("time = millis()%1000" == 0) the currPattern variable increments, and the next pattern gets displayed.
To display the pattern, each LED is accessed one at a time, and either turned on or off, depending if the corresponding coordinates in the pattern contain a 1 or 0. This happens very fast, so it looks like more than one LED is on (because of persistance of vision).
Anyway, the problem I'm having is in the setup function where I define my patterns (simple test patterns for now, all 1's or all 0's). I get the following error:
In function 'void setup()':
error: expected primary-expression before '{' token In function 'void loop()':
In function 'void runRow(int)':
Which is totally meaningless to me. Any hints?
edit: fixed some other problems. If I use for loops to define the patterns in the setup function, I can get it to compile, but for loops are only useful for simple patterns like all 1's or all 0's, not for more complex patterns that I plan to implement.
