Multi function touch sensor
Hello,
Can anyone help me program 1 touch sensor to control multiple servos by the amount of taps to the sensor? Servo1 open one tap, servo 2 open on 2 taps, servo 3 open on 3 taps & all servos close on 4 taps?
By reading this, you can already tell I’m a noob lol
Will servo 2 be required to open before servo 1 or will they open in sequence ?
I ask because the first tap for servo 2 could be interpreted as the tap for servo 1
Each servo serves an individual function, what I 3d printed is an iron man arm from the shoulder to the forearm,
Servo 1 controls 6 servos as the forearm rockets that all open together with a touch sensor tap
Servo 2 controls the shoulder flap to move up & down also by a touch sensor tap
The bicep & the forearm each have a servo for them to open up to free your arm, those servos are separate from the servos used for the forearm rockets & shoulder.
Vey interesting, but you did not answer my question
Can you see the problem of differentiating between the tap for servo 1 and the first tap for servo 2 ?
I apologize, yes I see the interference between taps, what would your best approach be for this? So far I have the 6 forearm servos functioning properly, I’ve thought of using separate touch sensors for the other servos however I also have trouble coding multiple touch sensors, 1 touch sensor controls all servos connected to the arduino pins. My project is on ig if you’d like to take a look, my ig is Idreamof3d. I’m building an entire motorized iron man suit & have little knowledge about arduino :sweat:
Separate touch sensors for each function would make things considerably simpler
What problems do you have coding for them ?
I don’t exactly know how to assign each touch sensor to a specific servo
The clumsy but simple way to code it would be a series of if statements
if sensor 0 has become touched
  do this
else if sensor 1 has become touched
  do this
else if sensor 2 has become touched
  do this
end if
Note that you need to detect that a sensor has become touched rather than it is touched
Clumsy is ok if it works correctly :joy:, I appreciate your help & im going to run tests
Hello idreamof3d
Consider this pseudo code:
touchSensor == touched ? servo.write(Open) : servo.write(Closed);
hth
What would go where the ? Is? May I have a bit more clarity with this?
Again I apologize for being such a noob
The conditional operator (?: )
if (condition)
    statement1;
    statement2;
https://www.learncpp.com/cpp-tutorial/comma-and-conditional-operators/
Thank you! I’ll also look into this
This is for 1 touch sensor with multiple functions?
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
int angle3 = -35;
myservo3.write(angle3);
The write() function takes positive integer as it's parameter
My apologies for that
Please edit your post and put < CODE > tags round the code
To do what you initially asked, you need to specify what the min/max interval is to identify adjacent taps.
Use millis() to achieve this, then count and act on those taps as needed.
Hello idreamof3d
Post the datasheet of touch sensor used.
