I hope this message finds you well.
I am not very familiar with programming. etc but keen to learn ...I would like your opinion regarding how complicated do you believe this project can be.
I would like to have several hygrometer and thermometer sensors ( ideally 6) located in different places on the same.room ( floor, close to window, ceiling etc) and connected via WiFi in order to have on my phone the readings.
I guess if I wanted to do this I would start by choosing a sensor or sensors. You choose your sensors based on temperature and humidity range you want to measure and the sensor uncertainty (accuracy). Once you decide on a sensor which will give you the data you want you choose a micro-controller which will process your data and since you want to view the data on a smart phone you need WiFi capability.
Unless you wish to take your project to the paid help section nobody here is going to build your project for you. You can get guidance but you are expected to do the work. I agree with:
