multi rfid reader sketch issue
I have in issue with the sketch not working the way I think it should!
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
// If using the breakout with SPI, define the pins for SPI communication.
#define PN532_SCK  (2)
#define PN532_MOSI (3)
#define PN532_SS   (4)
#define PN532_MISO (5)
#define PN532_SS2   (6)
// If using the breakout or shield with I2C, define just the pins connected
// to the IRQ and reset lines.  Use the values below (2, 3) for the shield!
#define PN532_IRQ   (2)
#define PN532_RESET (3)  // Not connected by default on the NFC Shield
// Uncomment just _one_ line below depending on how your breakout or shield
// is connected to the Arduino:
// Use this line for a breakout with a SPI connection:
Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
Adafruit_PN532 nfc2(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS2);
// Use this line for a breakout with a hardware SPI connection.  Note that
// the PN532 SCK, MOSI, and MISO pins need to be connected to the Arduino's
// hardware SPI SCK, MOSI, and MISO pins.  On an Arduino Uno these are
// SCK = 13, MOSI = 11, MISO = 12.  The SS line can be any digital IO pin.
//Adafruit_PN532 nfc(PN532_SS);
// Or use this line for a breakout or shield with an I2C connection:
//Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
// also change #define in Adafruit_PN532.cpp library file
//   #define Serial SerialUSB
#endif
void setup(void) {
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.println("Didn't find PN53x board 1");
    //while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
    // configure board to read RFID tags
  nfc.SAMConfig();
  nfc2.begin();
  uint32_t versiondata2 = nfc2.getFirmwareVersion();
  if (! versiondata2) {
    Serial.println("Didn't find PN53x board 2");
  Serial.print("Found chip PN5"); Serial.println((versiondata2>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata2>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata2>>8) & 0xFF, DEC);
  nfc2.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  ReadRFID1();
  ReadRFID2();
void ReadRFID1(){
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (!success){
    ReadRFID2();
  else if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card 1");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      uint32_t cardid = uid[0];
      cardid <<= 8;
      cardid |= uid[1];
      cardid <<= 8;
      cardid |= uid[2];
      cardid <<= 8;
      cardid |= uid[3];
      Serial.print("Seems to be a Mifare Classic card #");
      Serial.println(cardid);
    Serial.println("");
  else{
     Serial.println("No card at reader 1");
void ReadRFID2(){
  //// Look at second reader
  delay(200);
  uint8_t uid2[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength2;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  uint8_t success2;
  success2 = nfc2.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid2, &uidLength2);
  if (!success2){
    ReadRFID1();
  if (success2) {
    Serial.println("Found an ISO14443A card 2");
    Serial.print("  UID Length: ");Serial.print(uidLength2, DEC);Serial.println(" bytes");
    nfc2.PrintHex(uid2, uidLength2);
    if (uidLength2 == 4)
      uint32_t cardid = uid2[0];
      cardid <<= 8;
      cardid |= uid2[1];
      cardid <<= 8;
      cardid |= uid2[2];
      cardid <<= 8;
      cardid |= uid2[3];
    Serial.println("");
  else{
    Serial.println("No card at 2nd reader");
IF
 ReadRFID1();
  ReadRFID2();
Then it will read the tag if at ReadRFID1 but not ReadRFID2 unless I read ReadRFID1 first
Then I have to read a tag at ReadRFID2 then I can read a tag at ReadRFID1 again.
If
 ReadRFID2();
  ReadRFID1();
it will read the tag if at ReadRFID2 1st then I can read a tag at ReadRFID1 then I can read a tag at ReadRFID2 again.
for some resone, it is holding at the first Read and waiting there for a tag to be read how would I make this non-blocking?
  if (!success){
    ReadRFID2();
  else if (success) {
If success is not true, the else statement will be skipped. If success is true, the else statement will be executed. The if part of the else statement is useless.
void ReadRFID2(){
  delay(200);
Why?
That's rather a silly question when you have explicitly added delay() calls.
Thanks Paul I meant to change that.
I have it working somewhat here is the code:
#include <Wire.h>
#include <SPI.h>
#endif
void setup(void) {
  nfc.begin();
  nfc.SAMConfig();
  nfc2.begin();
  nfc2.SAMConfig();
void loop(void) {
  ReadRFID1();
  ReadRFID2();
void ReadRFID1(){
  Serial.println("Ready at RFID 1");
  uint8_t success;
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength, 100);
  if (!success){
    ReadRFID2();
  if(success) {
    if (uidLength == 4)
      cardid <<= 8;
      cardid |= uid[1];
      cardid <<= 8;
      cardid |= uid[2];
      cardid <<= 8;
      cardid |= uid[3];
    Serial.println("");
  else{
void ReadRFID2(){
  Serial.println("Ready at RFID 2");
  uint8_t success2;
  success2 = nfc2.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid2, &uidLength2, 100);
  if (!success2){
    ReadRFID1();
  if (success2) {
      cardid <<= 8;
      cardid |= uid2[1];
      cardid <<= 8;
      cardid |= uid2[2];
      cardid <<= 8;
      cardid |= uid2[3];
    Serial.println("");
  else{
The current issue is that after a few minutes of reading it just freezes somewhere after
After some testing, I found that the shorter the timeout the faster it freezes
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength, 50);
I added watchdog to keep it running, but I would like to find the problem! Thanks for your help
Possibly not related to the problem, but, given that loop() is going to read both devices anyway, what is the point of having ReadRFID1() call ReadRFID2()? Reading from the two devices should be completely independent activities.
I don't know why but that was the issue! Thanks
