multidimensional array
I have a multidimensional array, but the number of values is not fixed.
{0},{1,9},{2,8,10}
this doesn’t work : int columns[3] = {{0},{1,9},{2,8,10}};
this compiled : int columns[3][3] = {{0},{1,9},{2,8,10}};
But in my loop, if I use sizeof() it always returns 3, even if I have less values :
for( int i = 0; i < 3; i++) {
int numLeds = sizeof(columns*) / sizeof(int);*
  • Serial.println(numLeds);*
  • delay(1000);*
  • for( int j = 0; j < numLeds; j++) {*
    I was thinking of another way
    col1 = {0};
    col2 = {1,9};
    col3 ={2,8,10}
    but I can’t use a loop since there is no eval() function in arduino :
  • arrayColumns = eval(‘col’ + i)*
    Is there a way to do this in a dynamic manner, i would like to avoid writing code for every array …
    Thank you
C and C++ don't do non-rectangular arrays.
You can have a list of pointers to lists:
int column1[] = {0};
int column2[] = {1,9};
int column3[] = {2,8,10};
int *columns[] = {column1, column2, column3};
The problem with that is that it only allow you to get the length of the first level: sizeof columns / sizeof columns[0] == 3
But you can't get the length of each column because you can't use sizeof through a pointer: sizeof columns[2] == 2 (the size of an int pointer) sizeof columns[2][0] == 2 (the size of an int)
You could store the length of each column in the lists:
int column1[] = {1, 0};
int column2[] = {2,1, 9};
int column3[] = {3, 2, 8, 10};
Or you could put EOL markers in each list: You could store the length of each column in the lists:
int column1[] = {0, -1};
int column2[] = {1, 9, -1};
int column3[] = {2, 8, 10, -1};
