Multilpe variables from Matlab to Arduino
Im trying to send multiple variables from Matlab to Arduino and I cant work it out.
I was succesfull with ONE variable using this guide: How To Send Data From MATLAB To Your Arduino
But unfortunately I cant send MORE of them. I bet it is just simple solution, but i just cant solve it.
Variables I am trying to get are numbers. I was experimenting with Serial.parseInt() but I just cant get it right :confused: can you provide an example in you answer please?
Thank you!
Simple serial code that captures a comma , delimited string from the serial monitor, evaluates the captured String, then operates the arduino LED if the appropriate data has been received.
//zoomkat 3-5-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//send on, or off, from the serial monitor to operate LED
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial LED on/off test with , delimiter"); // so I can keep track
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      Serial.println(readString); //prints string to serial port out
      //do stuff with the captured readString
      if(readString.indexOf("on") >=0)
        digitalWrite(ledPin, HIGH);
        Serial.println("LED ON");
      if(readString.indexOf("off") >=0)
        digitalWrite(ledPin, LOW);
        Serial.println("LED OFF");
      readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
