Hello!
So I am pretty new to electronics and all that, so my question will probably be really stupid. Anyway, I want to connect 5 LEDs and a thermistor to attiny85. I managed to do that but I haven't got any other battery suitable for my project size other that a 9V. But I need 4 - 5.5 V for attiny85, so I need to lower the voltage. I was thinking of making the voltage divider so it gets me 4.5 v. I know I need two resistors of same value in series and 4.5V will be where they connect. But as a total noob with multimeter I don't know where to put my two thingies to check if the voltage is 4.5V. The red cable of multimeter goes to the divider output and the other to ground? I tried and it doesn't give my anything. With that I just want to make sure it works before I start putting LEDs. Also, everyone puts two 10k ohm resistors in series(even tho they say it doesn't matter as long as they have the same value). So can I put my two 1 ohm resistors in series? Will that change anything? I attached a picture so you can see how I connected everything before checking it with multimeter. I hope you can help me, sorry if this is a dumb post but I can't find how to connect multimeter to voltage divider circuit anywhere online
Best regards
Me.
