Multimeter shows 3x actual voltage
hey people,
since I measured a cap my multimeter has been showing the wrong values for volt. a full 1,5V AA battery shows around 6,5V and a 9V battery shows around 25~30V.
I took the meter apart but can't see any immediate damages or shorts.
Does anyone know what is actually wrong with it?
does it show this factor on every selection? or 0-10V only? Do you have a schematic of your voltmeter?
Probably 'cooked' one of the input voltage divider ranging resistors, but other failure modes are possible. Time to get a new meter. The best digital multimeter have pretty good input protection circuitry up to the maximum rated input voltage. Do you have link to your specific meter?
Lefty
I friend a cheap multimeter and it unfortunately just gave me incorrect readings rather than any kind of indication that it was broken.
stoopkid: I friend a cheap multimeter and it unfortunately just gave me incorrect readings rather than any kind of indication that it was broken.
Y'heard me!
stoopkid: Y'heard me!
I like your style.
Anyway, the multimeter is a HoldPeak HP-760B
Also, I have an older one that has the same problem (also tried measuring a cap with it..), it doesn't have a model or brand name though. I've taken them both apart, to see if any resistors are burnt or any other damages are visible. No luck so far.
Shame really, I liked the HoldPeak Multimeter.
