Hello!
I'm thinking about a project for my home.
I need to connect multiple devices to a central webserver that receives data and store it in a mysql database.
How can i send commands to arduinos directly from the webserver? (closing/opening a relay).
I need to connect from anywhere to a same webserver that wil show the data from all my arduinos instead connecting to each arduino device.
I'm thinking about creating multiple device to put in my home. I can use them for switching lights, switching plugs, monitoring temperature, power consumption, etc.
Servers generally do not send commands (return data) without a client making a request for them. The server can generate a web page for a client browser that has command buttons (or text box) that the user can use to send commands to the arduinos.
The Link generated by arduino it's working if i paste it to chrome, but when arduino acces the link as a client it's not saved on database.
#include <SPI.h>
#include <Ethernet.h>
// MAC address for your controller
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Numeric IP of the server where your website is stored.
IPAddress server(192,168,0,114);
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192,168,0,123);
// Initialize the Ethernet client library
EthernetClient client;
int sensorPin = A0;
int temperature = 0;
const char usermobile[11] = "0123456789";
const char usermail[40] = "rotaruco1@gmail.com";
const char username[40] = "RotaruCos";
// start serial connection
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
}//close setup
temperature = analogRead(sensorPin);
//Here would go the code to get the temperature value of your sensor.
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Send data using GET variable
client.print("GET /add.php?");
client.print("username=");
client.print(username);
client.print("&");
client.print("usermail=");
client.print(usermail);
client.print("&");
client.print("usermobile=");
client.print(usermobile);
client.println( " HTTP/1.1");
client.print( "Host: " );
client.println(server);
client.println( "Connection: close" );
client.println();
Serial.println(username);
Serial.println(usermail);
Serial.println(usermobile);
//Printing in the serial monitor what is going on
Serial.println("Sucessful connection. Data sent");
delay(5000);
else {
Serial.println("Connection failed");
client.stop();
client.flush();
I think i made it to work.Now, the arduino act like a webserver and, in parralel, once per minute sends data to mysql using that link. I'm still working on this.
I need the arduino to act like a webserver so i can send comands to it. I wil need it to switch relays, control mottors, or control ir led.
If you want you can take a look and see if there is something that can be inproved.
Thank you zoomkat.
//zoomkat 12-08-11, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 4 high/low
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
IPAddress ip(192,168,0,123); // ip in lan
IPAddress gateway(192,168,0,1); // internet access via router
IPAddress subnet(255,255,255,0); //subnet mask
IPAddress myserver(192,168,0,114); // zoomkat web page
EthernetServer server(84); //server port
String readString;
int sensorPin = A0;
int temperatura = 0;
// constants won't change. Used here to set a pin number :
const int ledPin = 13; // the number of the LED pin
// Variables will change :
int ledState = LOW; // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change :
const long interval = 60000; // interval at which to blink (milliseconds)
pinMode(4, OUTPUT); //pin selected to control
Ethernet.begin(mac, ip, subnet, gateway);
server.begin();
Serial.println("server/client 1.0 test 12/08/11"); // keep track of what is loaded
void loop(){
// check for serial input
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println("HTTP/1.1 204 Zoomkat");
client.println();
client.println();
else {
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
//client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
client.println("<IFRAME name=inlineframe style=\"display:none\" >");
client.println("</IFRAME>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("on") >0)//checks for on
digitalWrite(4, HIGH); // set pin 4 high
Serial.println("Led On");
if(readString.indexOf("off") >0)//checks for off
digitalWrite(4, LOW); // set pin 4 low
Serial.println("Led Off");
//clearing string for next read
readString="";
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
sendGET(); // call sendGET function
void sendGET() //client function to send/receie GET request data.
temperatura = analogRead(sensorPin);
if (client.connect(myserver, 80)) {
client.print("GET /addtemp.php?temperatura=");
client.println(temperatura);
client.println("HTTP/1.1");
client.println("Host: 192.168.0.114:80");
client.println("Connection: close");
client.println();
Serial.println("TEMPERATURA=");
Serial.print(temperatura);
else {
Serial.println("connection failed");
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
Serial.print(c);
Serial.println("disconnecting.");
Serial.println("==================");
client.stop();
Combined client/server test code.
//zoomkat 10-02-14, combined client and server
//open serial monitor and send a g to test client GET and
//web page buttons make pins high/low
//use the ' in html instead of " to prevent having to escape the "
#include <SPI.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = {192, 168, 1, 102 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 1, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port arduino server will use
char serverName[] = "checkip.dyndns.com"; // (DNS) dyndns web page server
//byte serverName[] = { 208, 104, 2, 86 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//pinMode(5, OUTPUT); //pin 5 selected to control
Ethernet.begin(mac,ip,gateway,gateway,subnet);
server.begin();
Serial.println(F("server/client 1.0 test 9/02/14")); // keep track of what is loaded
Serial.println(F("Send a g in serial monitor to test client")); // what to do to test client
void loop(){
if (Serial.available() > 0)
byte inChar;
inChar = Serial.read();
if(inChar == 'g')
sendGET(); // call client sendGET function
if (client) {
readString += c;
//Serial.print(c);
if (c == '\n') {
Serial.print(readString); //print to serial monitor for debuging
client.println();
client.println();
else {
client.println(F("HTTP/1.1 200 OK")); //send new page on browser request
client.println(F("Content-Type: text/html"));
client.println();
client.println(F("<HTML>"));
client.println(F("<HEAD>"));
client.println(F("<TITLE>Arduino GET test page</TITLE>"));
client.println(F("</HEAD>"));
client.println(F("<BODY>"));
client.println(F("<H1>Zoomkat's simple Arduino 1.0 button</H1>"));
// DIY buttons
client.println(F("Pin5"));
client.println(F("<a href=/?on2 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off3 target=inlineframe>OFF</a>
client.println(F("Pin6"));
client.println(F("<a href=/?on4 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off5 target=inlineframe>OFF</a>
client.println(F("Pin7"));
client.println(F("<a href=/?on6 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off7 target=inlineframe>OFF</a>
client.println(F("Pin8"));
client.println(F("<a href=/?on8 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off9 target=inlineframe>OFF</a>
client.println(F("Pins"));
client.println(F(" <a href=/?off2468 target=inlineframe>ALL ON</a>"));
client.println(F(" <a href=/?off3579 target=inlineframe>ALL OFF</a>"));
client.println(F("<IFRAME name=inlineframe style='display:none'>"));
client.println(F("</IFRAME>"));
client.println(F("</BODY>"));
client.println(F("</HTML>"));
delay(1);
//stopping client
client.stop();
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println(F("Led 5 On"));
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println(F("Led 5 Off"));
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println(F("Led 6 On"));
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println(F("Led 6 Off"));
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println(F("Led 7 On"));
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println(F("Led 7 Off"));
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println(F("Led 8 On"));
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println(F("Led 8 Off"));
readString="";
void sendGET() //client function to send and receive GET data from external server.
if (client.connect(serverName, 80)) {
Serial.println(F("connected"));
client.println("GET / HTTP/1.1");
client.println("Host: checkip.dyndns.com");
client.println();
else {
Serial.println(F("connection failed"));
char c = client.read(); //gets byte from ethernet buffer
readString += c; //places captured byte in readString
//Serial.println();
client.stop(); //stop client
Serial.println(F("client disconnected."));
Serial.println(F("Data from server captured in readString:"));
Serial.print(readString); //prints readString to serial monitor
Serial.println(F("End of readString"));
Serial.println(F("=================="));
readString=""; //clear readString variable
