Multiple Acceleration output from 'AccelGyro' code
Hello all,
I am new to Arduino and to this forum so I hope you will forgive me if I am not up to speed with the correct way of doing things.
I have downloaded the AccelGyro code on to my Arduino Mega 2560, it compiled ok but when I ran the Serial Monitor I saw that for every line representing the acceleration and Gyroscope readings from my MPU9150 chip there was a further two duplication (three lines of the same readings).
I am not sure if I have set up the Arduino incorrectly or if there is something missing from the code that I need to include because I am using the Mega 2560. See below a section of the Serial Monitor output.
Initializing I2C devices…
Testing device connections…
MPU6050 connection successful
a/g: 76 396 16812 -27 -63 196
a/g: -312 424 16728 188 263 160
a/g: 8 488 16732 -76 -87 218
a/g: -20 324 16688 -11 -29 188
a/g: -116 336 16904 -66 -54 212
a/g: 48 456 16924 -49 -71 191
a/g: -76 416 16804 -57 -75 170
a/g: -64 376 16736 -180 -264 198
a/g: -28 420 16912 -93 -180 189
Does anybody know why this duplication is occuring? Your help will be much appreciated.
AccelGyro.ino (5.99 KB)
I'm only guessing here, but maybe your gyro/accel doesn't have any new values since you last called the getmotion6 function. You'r loop doesn't do much, so is probably running quite quickly.
As a quick test, put a delay(100) at the bottom of your loop and see if the repeats go away.
tammytam:
I’m only guessing here, but maybe your gyro/accel doesn’t have any new values since you last called the getmotion6 function. You’r loop doesn’t do much, so is probably running quite quickly.
tammytam:
tammytam:
Thanks TammyTam the delay seemed to work fine.
Excellent. Now if there is no function call to return whether a value is ready, I would instead remove that delay and set up a timer that polls the gyro at set intervals. This stops your program blocking when you need to do other stuff.
OK, I have GPS on my Arduino so I could try using the time stamp from this or I could set the sample rate on the MPU9150 so the accelertion values are linked to a time interval?
I have added a ‘For’ loop to count the accelerometer and Gyroscope readings from the MPU9150. I set the MPU9150 sample rate to 50Hz, which is the upper limit in the ‘For’ loop, but I am not sure if the readings are at specific time intervals within the sample rate or just the ‘For’ loop count. I suspect they are the latter.
I am trying to get acceleration values at a specific frequency (known time interval) so I can then calculate the velocity and then displacement. I am not sure I have done this correctly within the code!
Does anybody know how to get the acceleration output from the MPU9150 at a specific sample rate so that the acceleration readings are at specific time intervals?
Here is my code
[color=blue]// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050.h"
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
//MPU6050 accelgyro(0x69); // <-- use for AD0 high
int16_t ax, ay, az;
int16_t gx, gy, gz;
// uncomment "OUTPUT_READABLE_ACCELGYRO" if you want to see a tab-separated
// list of the accel X/Y/Z and then gyro X/Y/Z values in decimal. Easy to read,
// not so easy to parse, and slow(er) over UART.
#define OUTPUT_READABLE_ACCELGYRO
// uncomment "OUTPUT_BINARY_ACCELGYRO" to send all 6 axes of data as 16-bit
// binary, one right after the other. This is very fast (as fast as possible
// without compression or data loss), and easy to parse, but impossible to read
// for a human.
//#define OUTPUT_BINARY_ACCELGYRO
#define LED_PIN 13
bool blinkState = false;
unsigned long PreviousBit = 0;
unsigned long SampleRate;
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    Serial.begin(38400);
    // initialize device
    Serial.println("Initializing I2C devices...");
    accelgyro.initialize();
    // verify connection
    Serial.println("Testing device connections...");
    Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
    // use the code below to change accel/gyro offset values
    Serial.println("Updating internal sensor offsets...");
    // -76	-2359	1688	0	0	0
    Serial.print(accelgyro.getXAccelOffset()); Serial.print("\t"); // -76
    Serial.print(accelgyro.getYAccelOffset()); Serial.print("\t"); // -2359
    Serial.print(accelgyro.getZAccelOffset()); Serial.print("\t"); // 1688
    Serial.print(accelgyro.getXGyroOffset()); Serial.print("\t"); // 0
    Serial.print(accelgyro.getYGyroOffset()); Serial.print("\t"); // 0
    Serial.print(accelgyro.getZGyroOffset()); Serial.print("\t"); // 0
    Serial.print("\n");
    accelgyro.setXGyroOffset(220);
    accelgyro.setYGyroOffset(76);
    accelgyro.setZGyroOffset(-85);
    Serial.print("\n");
    // configure Arduino LED for
    pinMode(LED_PIN, OUTPUT);
    //Set the MPU9150 acceleration range to +/-2g
    accelgyro.setFullScaleAccelRange(MPU6050_ACCEL_FS_2);
    //Set the sample rate divider value
    accelgyro.setRate(19);
    SampleRate = (1000.00/( 1.00 + accelgyro.getRate()));   // get a status message every NN ms equal to the sample rate
    //Print sample rate
    Serial.print("Sample Rate = ");
    Serial.print(SampleRate);
    Serial.println(" bits/s");
    unsigned long currentBit;
    for (unsigned long currentBit=0; currentBit <= SampleRate-1; currentBit++){
    // read raw accel/gyro measurements from device
    accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    // these methods (and a few others) are also available
    //accelgyro.getAcceleration(&ax, &ay, &az);
    //accelgyro.getRotation(&gx, &gy, &gz);
    #ifdef OUTPUT_READABLE_ACCELGYRO
        // display tab-separated accel/gyro x/y/z values
        Serial.print("a/g:\t");
        Serial.print(currentBit); Serial.print("\t");
        Serial.print(ax); Serial.print("\t");
        Serial.print(ay); Serial.print("\t");
        Serial.print(az); Serial.print("\t");
        Serial.print(gx); Serial.print("\t");
        Serial.print(gy); Serial.print("\t");
        Serial.println(gz);
        //delay(100);
    #endif
    #ifdef OUTPUT_BINARY_ACCELGYRO
        Serial.write((uint8_t)(ax >> 8)); Serial.write((uint8_t)(ax & 0xFF));
        Serial.write((uint8_t)(ay >> 8)); Serial.write((uint8_t)(ay & 0xFF));
        Serial.write((uint8_t)(az >> 8)); Serial.write((uint8_t)(az & 0xFF));
        Serial.write((uint8_t)(gx >> 8)); Serial.write((uint8_t)(gx & 0xFF));
        Serial.write((uint8_t)(gy >> 8)); Serial.write((uint8_t)(gy & 0xFF));
        Serial.write((uint8_t)(gz >> 8)); Serial.write((uint8_t)(gz & 0xFF));
    #endif
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
    PreviousBit = currentBit;
}[/color]
code]
Yea all that loop is doing, is grabbing the accel values whether they are new or not, most likely not ;)
Is this your unit?:
module datasheet
If so, looks like your max rate on the accelerometer gyros is 8 KHz.
Also, calculating displacement from acceleration on these things is hard/unreliable/inaccurate, the inaccuracy increases the longer you attempt to calculate displacement over.
Yes this is the unit I am using (InvenSense MPU9150)
I am not looking for a high sample rate, somewhere between 50 and 200 bits/s, but this will depend upon the measurements I get and if I will need to increase this value once I have seen the results.
I have heard this is difficult but would like to give it a go and see what issues I get. My thought is that I sample at a suficiently high rate and periodically zero the displacement so the integration does not applify the error.
