i just started programming and I would like to have some help with performing several actions at the same time.
I found a code online and modified it a bit:
#include <Servo.h>
Servo myservo1;
Servo myservo2;// create servo object to control a servo
// twelve servo objects can be created on most boards
int pos1 = 0; // variable to store the servo position
int pos2 = 90;
myservo1.attach(9); // attaches the servo on pin 9 to the servo object
myservo2.attach(10);
for (pos1 = 0; pos1 <= 90; pos1 += 1) { // goes from 0 degrees to 180 degrees // in steps of 1 degree
myservo1.write(pos1); // tell servo to go to position in variable 'pos'
delay(5); // waits 15ms for the servo to reach the position
for (pos2 = 90; pos2 >= 0; pos2 -= 1) { // goes from 180 degrees to 0 degrees
myservo2.write(pos2); // tell servo to go to position in variable 'pos'
for (pos1 = 90; pos1 >= 0; pos1 -= 1) { // goes from 180 degrees to 0 degrees
for (pos2 = 0; pos2 <= 90; pos2 += 1) { // goes from 180 degrees to 0 degrees
My problem is that the program is performing every action one by one, but i would like to perform the two first action followed by Nr3 and 4.
Thanks in advance!
