multiple adxl 343
hi, i want to run two adafruit adxl343's at the same time, does anyone know if you can change the i2c address on the breakout?
when i run the i2c scanner it finds one at 0x53 even if both are connected.
many thanks
update: found that pin12 should change the address if its grounded - however ive tried this with a 10k resistor and just a jumper and it doesnt do anything
https://learn.adafruit.com/assets/70558
Use SPI, with different CS pins.
