Multiple ADXL362 project
I’m trying to connect 8 ADXL362 accelerometers to an Arduino DUE using SPI protocol
ADXL362:
SPI:
https://learn.sparkfun.com/tutorials/serial-peripheral-interface-spi
If possible, I need to hear from you some guidelines on the preferred way of connection as well as writing a program that takes reading from these sensors, and what additions to the following code to add
There is an example that works with one sensor that is:
#include <SPI.h>
#include <ADXL362.h>
ADXL362 xl;
int16_t temp;
int16_t XValue, YValue, ZValue, Temperature;
void setup(){
xl.begin(10); // Setup SPI protocol, issue device soft reset
xl.beginMeasure(); // Switch ADXL362 to measure mode
Serial.println(“Start Demo: Simple Read”);
void loop(){
// read all three axis in burst to ensure all measurements correspond to same sample time
xl.readXYZTData(XValue, YValue, ZValue, Temperature);
Serial.print(“XVALUE=”);
Serial.print(XValue);
Serial.print("\tYVALUE=");
Serial.print(YValue);
Serial.print("\tZVALUE=");
Serial.print(ZValue);
Serial.print("\tTEMPERATURE=");
Serial.println(Temperature);
delay(100); // Arbitrary delay to make serial monitor easier to observe
Thanks All,
