Hi All,
I’m new to arduino and I’ve got quite an optimistic project on the go that uses 12 x proximity sensors at once (sharp GP2Y0A02YK0F) for use with MAX MSP. I went and bought an arduino mega2650 as it has 16 analog inputs.
After following this tutorial: http://colinzyskowski.com/?page_id=503 it was all working fine with 3 inputs, but when I try to add a 4th there doesn’t seem to be any data coming in. I’m thinking this might be because there’s a limit to how much data can be sent using Serial.write, however on the tutorial he states if you just add int val4; analogRead(3); val4 = map(val4, 0, 1023, 301, 400); and Serial.write(val4); to the Arduino code I should be able split/parse the data back in Max as I have done with the previous 3 sensors.
Is there a better way to get 12 streams of data from the Arduino into Max? Has anyone encountered any similar issues?
Thanks in advance!
Jack
