Hey guys
I have three arduinos connected together for SPI as below. The master has a pot connected to A1 and it should send the mapped value to S1 and the reversed mapped value to S2 (I'm reversing it because I don't have a second Pot on hand). This doesn't work thou, I think it might have something to do with the SS pins 9 and 10 out of the master.
This is a early test for a project were I need three steppers each connected to their own arduinos and values for positioning is sent over SPI from the master. Let me know if this is the best way of going about things
Thanks
Ian
M-->S1->S2
09------->10 S2
10------->10 S1
11->11->11
12->12->12
13->13->13
MASTER
// master
#include <SPI.h>
#include "SPI_anything.h"
// create a structure to store the different data values:
typedef struct myStruct
int a;
int b;
int val;
int valtwo;
myStruct foo;
void setup ()
SPI.begin ();
// Slow down the master a bit
SPI.setClockDivider(SPI_CLOCK_DIV128);
pinMode(A1, INPUT);
foo.b = 0;
foo.a = 0;
} // end of setup
void loop ()
int potanalog = analogRead(1);
int valtwo = map(potanalog, 0, 1023, 255, 0);
int val = map(potanalog, 0, 1023, 0, 255);
foo.b = val;
foo.a = valtwo;
digitalWrite(10, LOW); // SS is pin 10
SPI_writeAnything (foo.b);
digitalWrite(10, HIGH);
digitalWrite(9, LOW); // SS is pin 10
SPI_writeAnything (foo.a);
digitalWrite(9, HIGH);
//delay (500); // for testing
} // end of loop
SLAVE 1
// slave1
#include <SPI.h>
int b;
myStruct foo;
void setup ()
// have to send on master in, *slave out*
pinMode(MISO, OUTPUT);
// turn on SPI in slave mode
SPCR |= _BV(SPE);
} // end of setup
void loop ()
SPI_readAnything (foo);
analogWrite(3, foo.b);
} // end of loop
SLAVE 2
// slave2
#include <SPI.h>
int a;
myStruct foo;
void setup ()
SPCR |= _BV(SPE);
} // end of setup
void loop ()
analogWrite(3,foo.a);
} // end of loop
SPI_anything.h
#include <Arduino.h>
template <typename T> unsigned int SPI_writeAnything (const T& value)
const byte * p = (const byte*) &value;
unsigned int i;
for (i = 0; i < sizeof value; i++)
SPI.transfer(*p++);
return i;
} // end of SPI_writeAnything
template <typename T> unsigned int SPI_readAnything(T& value)
byte * p = (byte*) &value;
unsigned int i;
*p++ = SPI.transfer (0);
return i;
} // end of SPI_readAnything
template <typename T> unsigned int SPI_readAnything_ISR(T& value)
unsigned int i;
*p++ = SPDR; // get first byte
for (i = 1; i < sizeof value; i++)
return i;
} // end of SPI_readAnything_ISR
