multiple BMP 180 using adafruit breakout boards
Can 4 BMP180 breakout boards connect to arduino mega ADK?
Thanks for any help
Can you set up 4 different I2C addresses with those modules? If not, you can use I2C multiplexer.
The BMP085 has only one address, a multiplexer would be necessary
An alternative is to buy BMP183 boards. The BMP183 has the same pressure sensor as the 180 but has an SPI interface making it easier to interface with multiple sensors.
