I was wondering if I have 8 buttons, can I have the negatives all tied together, then use a single resistor to go from that grouping to ground?
The buttons are momentary....
Also, could someone explain why you need a resistor? I've read in other topics it's to pull the arduino pin down to ground, but what does that mean? Why doesn't it automatically go down to ground?
In a sense you're right: you don't need a resistor to do the pulling down, you could use a wire for that.
BUT don't try it. Look at a schematic like say here: with no resistor, when the switch is closed there would be a direct short between the 5V and GND, and BOOM! something will pop.
When the switch is open, the pin is attached to ground and reads 0V; close the switch, the pin is taken to 5V. The pull down guarantees the pin is at 0V when the switch is open- without the pull down it could possibly just float around at any random value.
Thank you , that answers the second question very clearly. The resister is acting like a load to prevent short circuit... And the ground is needed to make sure the pin reads zero volts.
So I should be fine tying all the grounds from all my buttons together and then putting a resistor between them and ground.
Qdeathstar:
I think so, but I'm not 100% sure.
But, in any case, it's more usual to use pullUPs than pullDOWNs, and there's an easier way to do that in software. Simply pinMode the pin like this....
pinMode(x, INPUT_PULLUP);
..... with no need for external resistors, since that command enables the built-in ones.
Just be aware that pullUPs invert your logic from pullDOWN: closing the switch takes the pin low whereas before it took it high.
