Thanks for the reply!
I know the code I provided won't give the desired result, it was just more or less the foundation that I'm building off of.
I've been fighting with this all night and finally stripped it down to a single led, coded it as if it was a digital switch just provding high or low, and not an analog. Then I just went back and added my if() statements. Finally it works! Now I'd just need to add separate booleans for each of my four LEDS but I might actually be able to handle that. ![]()
If anyone is interested here is the working code:
Desired Effects:
Led One, When button one is pressed, LED one is On.
Do not change state untill button is released and pressed again.
// Define Constants
const int switcharrayPin=A0; // Set switch array pin to analog pin 0
const int ledonePin=11; // Set LED pin to 11
// Define Variables
boolean switchonecurrent=false; // Boolean to hold current switch position
boolean switchonelast=false; // Boolean to hold last switch position
long int switcharrayvalue=0; // Keep track of the switch value between 0 and 1280
pinMode (switcharrayPin, INPUT); //set switch array pin to an input
pinMode (ledonePin, OUTPUT); // set switch array pin to an output
switcharrayvalue=analogRead(switcharrayPin); // Read Switch Array
if(switcharrayvalue > 350 && switcharrayvalue < 550 && switchonelast==false)// See if switch one is pressed when it was not pressed before
switchonecurrent = !switchonecurrent; // If so, flip switch ones value
switchonelast=true; // If so, make switch ones last state to true
if(switcharrayvalue < 350 || switcharrayvalue > 550)// See if button one is not pressed
switchonelast=false; // If it's not, set switch ones last state to false
digitalWrite(ledonePin,switchonecurrent); // Write switch ones current state to LED One
