I have to wire two push buttons to the Arduino. I am simply using the circuit from http://arduino.cc/en/Tutorial/Button twice. I am using two digital pins, one for each button, but the issue is that when one button is pressed, the other buttons pin reads HIGH as well as it's connected to the same 5V/GND. Obviously I am doing something wrong in the circuit, so how am I actually supposed to set it up?
OK, stop using external pull-down resistors that you have to pay for, and use the free built-in pull-up resistors.
All you need are some simple modifications to your code.
I removed the resistor and enabled the internal pullup resistors. Now I can't get it to read anything but high. I will try measuring on the buttons, but they have worked when I only had one button.
Sadly I can't quite post the code as it's done in LabVIEW.
Edit: It actually seems that I am short circuiting the Arduino when a button is pressed.
The 5V and the GND are now connected directly when the button is pressed. There's no resistance between them at all.
I thought about what you said again, and changed the circuit to look like this (with internal pullup on pin 11-12).
Both pins still get pulled low when one is pressed.
Your diagram doesn’t make much sense - it appears your input pins are shorted together, so it isn’t surprising they both go low when a switch is operated
You’re right, I was a bit quick with that drawing. It really is like this, and both go to low when you press one of them.
I don’t see problems with the code, both pins are set to input, then I write high to them, and then I read the values in a loop.
I found the error, it wasn't that obvious but I had soldered two other wires together than I hadn't noticed Now that it's wired as in the last diagram I posted, it works perfectly. Thank you.
