multiple conditions for the same process
Hi Guys,
I am using a Mega 2560 for my project.
I want to use a ON/OFF button to control LEDs running in sequence (i.e. flashing in order)
A 4-pin rotary switch is used for dimming the brightness of LEDs.
Here is my code:
byte button = 7;
byte led[4] =
  2,3,4,5}; // 4 leds.
byte rSwitch[4] =
  8,9,10,11}; // 4-position rotary switch
unsigned long int brightness;
  pinMode(button, INPUT);
  for(int i = 0; i<4; i++)
    pinMode(led[i], OUTPUT);
  for(int a = 0; a<4; a++)
    pinMode(rSwitch[a], INPUT);
  if(digitalRead(button) == HIGH) // if button is pressed
    if(digitalRead(rSwitch[1]) == HIGH)  //select 1st brightness
      brightness = 10; // set brightness
      blink_led_task(); // blink LED function
    else if(digitalRead(rSwitch[2]) == HIGH)  //select 2nd brightness
      brightness = 50; // set brightness
      blink_led_task(); // blink button
    else if(digitalRead(rSwitch[3]) == HIGH)  //select 3rd brightness
      brightness = 100; // set brightness
    else if (digitalRead(rSwitch[4]) == HIGH) //select 2nd brightness
      brightness = 200; // set brightness
      digitalWrite(led[i], LOW); // turn off all led.
unsigned long blink_led_time;
void blink_led_task()
  if(millis() - blink_led_time > 500) // 500 ms.
    blink_led_time = millis();
    return;
  static byte number = 0;
    digitalWrite(led[i], LOW); // turn off all leds first.
  analogWrite(led[number], brightness);
  number++;
  if(number == 4)
    number = 0; // reset back to zero.
  // digitalWrite(led, digitalRead(led) ^ 1); // toggle led.
It compiles but does not work as I expected, nothing happens if I turn the rotary switch or press the button.
Actually it was developed from the old version:
byte button = 8;
byte led[4] = {
    return;
  digitalWrite(led[number], HIGH);
  number++;
  if(number == 4)
The original one works perfectly.
I couldn't see why it doesn't work after adding the rotary switch.
Could anyone give me advice and hints ? Thank you very much
Haven't you got a thread open about this in the Leds & Multiplexing section?
dannable:
I thought it should be quite basic problem for Arduino programming, may be it is better to place it under general Project Guidance.
But I went to the Microcontrollers one wrongly.
Sorry for duplicating.
Your array only has 4 elements. You start by reading element "1" and finish by reading element "4", which doesn't exist. I think you meant to use 0, 1, 2, and 3.
byte led[4] =  {2,3,4,5}; // 4 leds.
Pins 2 and 4 aren't PWM pins and do not support calls to analogWrite(). Well, it will still set them to HIGH or LOW, based on the value you pass.
brightness can't be more than 255. Why make it a long? It just needs to be an int, or even a byte.
Since you have not used the internal pull-up resistors on your INPUTs, have wired external pull-downs? (I assume so, since you are referencing the buttons as active HIGH).
Also, nothing will happen unless the button is pressed and held. Is that what you intended?
