So for my project, I want three different Arduinos:
One Mega for the main controller
and two pro minis as sub controllers.
I want them all to connect to the mega via bluetooth
I have this for the mega:
And two of these for the minis:
http://www.amazon.com/gp/product/B00DQ4A7O6/ref=oh_details_o08_s00_i00?ie=UTF8&psc=1
I want to connect to both the minis to both send and receive data. From what I can find out, it seems I can only have one connection at a time. So I'm thinking of quickly connecting back and forth just long enough to send/receive data from that sub controller. Is there a library out there to make this easier or a tutorial to help me do it myself? Most of the things I'm finding seem to be out of date and don't work for various reasons.
Thanks
I'm struggling with same idea/problem. You are saying "From what I can find out, it seems I can only have one connection at a time. ". How did you find this out?
My problem is this:
raspberry with usb/BT-dongle
arduino mega with HC-05 BT module
arduino micro with HC-05 BT module
I want to connect arduinos to rasp so I that they send data to raspberry simultaneously. I can get them connected one at the time:
*root@raspberrypi:~# bt-device -l *
Added devices:
HCBLU (00:14:01:xx:xx:92)
root@raspberrypi:~# rfcomm -a
rfcomm0: 00:14:01:xx:xx:92 channel 1 clean
This runs a small software, which just echoes everything back and it works ok. When I try to add another arduino:
root@raspberrypi:~# echo "2000" | bt-device -c 00:14:01:xx:xx:89
Connecting to: 00:14:01:xx:xx:89
Agent registered
Device: muovi (00:14:01:xx:xx:89)
Enter PIN code: Agent released
Done
Added devices:
root@raspberrypi:~# rfcomm bind hci0 00:14:01:xx:xx:89 2
Can't create device: Address already in use
I have both BT's in /etc/bluetooth/rfcomm.conf and can get rfcomm to complete:
root@raspberrypi:~# rfcomm bind all
rfcomm1: 00:14:01:xx:xx:92 channel 2 clean
rfcomm2: 00:14:01:xx:xx:89 channel 1 clean
but as soon as I try to access them with minicom or screen:
root@raspberrypi:~# minicom
minicom: cannot open /dev/rfcomm1: Connection refused
rfcomm1: 00:14:01:xx:xx:92 channel 2 closed
So how could we use two at the same time? Any help appreciated!
-Proge
Answering to myself, need to use rfcomm connect, after that I can talk to two bt-devices at the same time..
-Proge
