Multiple Dallas onewire busses on one Arduino
I am trying to setup an Arduino with two onewire busses attached to it using the DallasTemperature library. Below is some sample code from the Dallastemperature library of setting up 2 ds18b20 sensors on one bus. I cannot figure out how to modify this code to add another onewire bus . Everything I try to add another bus will not compile.
I cannot find an example on the internet . Can some kind soul help me with this perplexing(to me) problem? Maybe what I am trying to do isnt even possible?
Thanks
Frank
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
void loop(void)
  // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  Serial.print("Requesting temperatures...");
  sensors.requestTemperatures(); // Send the command to get temperatures
  Serial.println("DONE");
  Serial.print("Temperature for the device 1 (index 0) is: ");
  Serial.println(sensors.getTempFByIndex(0));
  delay(2000);
  Serial.print("Temperature for the device 2 (index 1) is: ");
  Serial.println(sensors.getTempFByIndex(1));
delay(2000);
Add another OneWire instance?
OneWire oneWireA (2) ;
OneWire oneWireB (3) ;
DallasTemperature sensorsA (&oneWireA) ;
DallasTemperature sensorsB (&oneWireB) ;
BTW best not to say 'port' when you mean 'pin' - a port is an 8 bit thing in the AVR world, you'll cause confusion!
Well...you did it once again MarkT. Thanks I googled for hours looking for some sample code of using multiple onewire busses with Dallastemperature.
Frank
You do realize that you can put two (or many more) DS1820's on one 1-Wire line, I hope?
Best to avoid star topographies, though... that might be a reason for needing two 1-Wire busses.
