multiple definition error
i want to define a LiquidCrystal variable out of main unit.... but when compiling the whole program, "multiple definition" error occurs... :0
Hi Wally,
You really didn't provide enough detail for us to understand what you did or what you're trying to do...
Most likely you are creating a variable or type that already exists, or you are including a header file that has a definition that already exists in another one.
Pat
i want to create a library which contains routines that use LCD functions.
my library’s begining:
//lcd_lib.cpp
#include <LiquidCrystal.h>
LiquidCrystal sysMon(12, 11, 5, 4, 3, 2);
And main unit:
//main_unit.cpp
#include “Arduino.h”
#include “lcd_lib.cpp”
sysMon.begin(8,2,0);
if i compile this project in eclipse IDE, this message occurs:
…/lcd_lib.cpp:13: multiple definition of `sysMon’
./main_unit.o:(.bss.sysMon+0x0): first defined here
Ahhh. I see what you're doing... try it again without the following line:
include "lcd_lib.cpp"
You don't include CPP files into CPP files, or you will get duplicate code. The #include pre-processor operation essentially copies and pastes the included file into your CPP file before it compiles it. The compiler saw your sysMon definition twice.
thanks…
i used #include direktive with header file (lcd_lib.h) and problem solved…
:slight_smile: :slight_smile:
Great! Good luck with your project. LCDs can be a lot of fun.
Pat.
