multiple definition of `HX711::~HX711()'
I have work on Weight Sensor project with HX711. When i upload the code to MEGA board it's shows this error..
libraries\HX711-master\HX711.cpp.o (symbol from plugin): In function `HX711::~HX711()':
(.text+0x0): multiple definition of `HX711::~HX711()'
sketch\HX711.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `HX711::is_ready()'
(.text+0x0): multiple definition of `HX711::read()'
(.text+0x0): multiple definition of `HX711::set_gain(unsigned char)'
(.text+0x0): multiple definition of `HX711::HX711(unsigned char, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `HX711::read_average(unsigned char)'
(.text+0x0): multiple definition of `HX711::get_value(unsigned char)'
(.text+0x0): multiple definition of `HX711::get_units(unsigned char)'
(.text+0x0): multiple definition of `HX711::tare(unsigned char)'
(.text+0x0): multiple definition of `HX711::set_scale(float)'
(.text+0x0): multiple definition of `HX711::get_scale()'
(.text+0x0): multiple definition of `HX711::set_offset(long)'
(.text+0x0): multiple definition of `HX711::get_offset()'
(.text+0x0): multiple definition of `HX711::power_down()'
(.text+0x0): multiple definition of `HX711::power_up()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
What is the library you installed on your card?
If you used code tags when posting the error text as advised in read this before posting a programming question then it would not be littered with smilies as in your post. While you are at it, please post the code that causes the errors and links to any libraries used as suggested in the link above.
Please help us to help you.
