multiple definition of `sp' software Serial Arduino
hi i am developing send data through HTTP from GPRS Module . i found this code on this forum and did changes. but when i am trying to compile its showing me error.
Freematics-master\SIM800.cpp.o:(.bss.sp+0x0): multiple definition of `sp'
ACTALLYWORKING.cpp.o:(.bss.sp+0x0): first defined here
here is code "SIM800.h" --------------File-1
#include <Arduino.h>
#include <SoftwareSerial.h>
// change this to the pin connect with SIM800 reset pin
#define SIM800_RESET_PIN 7
// change this to the serial UART which SIM800 is attached to
SoftwareSerial  sp(7, 8);
#define SIM_SERIAL sp
// define DEBUG to one serial UART to enable debug information output
//#define DEBUG Serial
typedef enum {
    HTTP_DISABLED = 0,
    HTTP_READY,
    HTTP_CONNECTING,
    HTTP_READING,
    HTTP_ERROR,
} HTTP_STATES;
typedef struct {
  float lat;
  float lon;
  uint8_t year; /* year past 2000, e.g. 15 for 2015 */
  uint8_t month;
  uint8_t day;
  uint8_t hour;
  uint8_t minute;
  uint8_t second;
} GSM_LOCATION;
class CGPRS_SIM800 {
public:
    CGPRS_SIM800():httpState(HTTP_DISABLED) {}
    // initialize the module
    bool init();
    // setup network
    byte setup(const char* apn);
    // get network operator name
    bool getOperatorName();
    // check for incoming SMS
    bool checkSMS();
    // get signal quality level (in dB)
    int getSignalQuality();
    // get GSM location and network time
    bool getLocation(GSM_LOCATION* loc);
    // initialize HTTP connection
    bool httpInit();
    // terminate HTTP connection
    void httpUninit();
    // connect to HTTP server
    bool httpConnect(const char* url, const char* args = 0);
    // check if HTTP connection is established
    // return 0 for in progress, 1 for success, 2 for error
    byte httpIsConnected();
    // read data from HTTP connection
    void httpRead();
    // return 0 for in progress, -1 for error, bytes of http payload on success
    int httpIsRead();
    // send AT command and check for expected response
    byte sendCommand(const char* cmd, unsigned int timeout = 2000, const char* expected =
0);
    // send AT command and check for two possible responses
    byte sendCommand(const char* cmd, const char* expected1, const char* expected2,
unsigned int timeout = 2000);
    // toggle low-power mode
    bool sleep(bool enabled)
      return sendCommand(enabled ? "AT+CFUN=0" : "AT+CFUN=1");
    // check if there is available serial data
    bool available()
       return SIM_SERIAL.available();
    char buffer[256];
    byte httpState;
private:
    byte checkbuffer(const char* expected1, const char* expected2 = 0, unsigned int
timeout = 2000);
    void purgeSerial();
    byte m_bytesRecv;
    uint32_t m_checkTimer;
here is code "SIM800.cpp" --------------File-2
#include "SIM800.h"
 bool CGPRS_SIM800::init()
    //SIM_SERIAL.begin(9200);
    pinMode(SIM800_RESET_PIN, OUTPUT);
    digitalWrite(SIM800_RESET_PIN, HIGH);
    delay(10);
    digitalWrite(SIM800_RESET_PIN, LOW);
    delay(100);
    delay(3000);
    if (sendCommand("AT")) {
        sendCommand("AT+IPR=9200");
        sendCommand("ATE0");
        sendCommand("AT+CFUN=1", 10000);
        return true;
    return false;
 byte CGPRS_SIM800::setup(const char* apn)
  bool success = false;
  for (byte n = 0; n < 30; n++) {
    if (sendCommand("AT+CREG?", 2000)) {
        char *p = strstr(buffer, "0,");
        if (p) {
          char mode = *(p + 2);
#if DEBUG
          con.print("Mode:");
          con.println(mode);
#endif
          if (mode == '1' || mode == '5') {
            success = true;
  if (!success)
    return 1;
  if (!sendCommand("AT+CGATT?"))
    return 2;
  if (!sendCommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\""))
    return 3;
  SIM_SERIAL.print("AT+SAPBR=3,1,\"APN\",\"");
  SIM_SERIAL.print(apn);
  SIM_SERIAL.println('\"');
  if (!sendCommand(0))
    return 4;
  sendCommand("AT+SAPBR=1,1", 10000);
  sendCommand("AT+SAPBR=2,1", 10000);
  sendCommand("AT+CMGF=1");    // sets the SMS mode to text
  sendCommand("AT+CPMS=\"SM\",\"SM\",\"SM\""); // selects the memory
  if (!success)
    return 5;
  return 0;
 bool CGPRS_SIM800::getOperatorName()
  // display operator name
  if (sendCommand("AT+COPS?", "OK\r", "ERROR\r") == 1) {
      char *p = strstr(buffer, ",\"");
      if (p) {
          p += 2;
          char *s = strchr(p, '\"');
          if (s) *s = 0;
          strcpy(buffer, p);
          return true;
  return false;
void CGPRS_SIM800::purgeSerial()
  while (SIM_SERIAL.available()) SIM_SERIAL.read();
here is code "MySketch.Ino" --------------File-3
#include <SIM800.h>
#define APN "connect"
#define con Serial
static const char* url = "http://arduinodev.com/datetime.php";
CGPRS_SIM800 gprs;
uint32_t count = 0;
uint32_t errors = 0;
 // con.begin(9600);
  while (!con);
  con.println("SIM800 TEST");
  for (;;) {
    con.print("Resetting...");
    while (!gprs.init()) {
      con.write('.');
    con.println("OK");
    con.print("Setting up network...");
    byte ret = gprs.setup(APN);
    if (ret == 0)
    con.print("Error code:");
    con.println(ret);
    con.println(gprs.buffer);
  con.println("OK");
  delay(3000);
  if (gprs.getOperatorName()) {
    con.print("Operator:");
  int ret = gprs.getSignalQuality();
  if (ret) {
     con.print("Signal:");
     con.print(ret);
     con.println("dB");
  for (;;) {
    if (gprs.httpInit()) break;
    gprs.httpUninit();
  delay(3000);
  char mydata[16];
  sprintf(mydata, "t=%lu", millis());
  con.print("Requesting ");
  con.print(url);
  con.print('?');
  con.println(mydata);
  gprs.httpConnect(url, mydata);
  count++;
  while (gprs.httpIsConnected() == 0) {
    // can do something here while waiting
    con.write('.');
    for (byte n = 0; n < 25 && !gprs.available(); n++) {
      delay(10);
  if (gprs.httpState == HTTP_ERROR) {
    con.println("Connect error");
    errors++;
    delay(3000);
    return;
  con.println();
  gprs.httpRead();
  int ret;
  while ((ret = gprs.httpIsRead()) == 0) {
    con.println("Read error");
    errors++;
    delay(3000);
    return;
  // now we have received payload
  con.print("[Payload]");
  // show position
  GSM_LOCATION loc;
  if (gprs.getLocation(&loc)) {
    con.print("LAT:");
    con.print(loc.lat, 6);
    con.print(" LON:");
    con.print(loc.lon, 6);
    con.print(" TIME:");
    con.print(loc.hour);
    con.print(':');
    con.print(loc.minute);
    con.print(':');
    con.println(loc.second);
  // show stats
  con.print("Total Requests:");
  con.print(count);
  if (errors) {
    con.print(" Errors:");
    con.print(errors);
  con.println();
can you please tell me how can i correct above error . i am using arduino Uno development board.
What is the compiler trying to tell you? What happens if SIM800.h is included several time? How do you avoid multiple includes? And why should variables/instances not be created in a header file?
This is all the info you need to fix it.
Cheers!
its only included in sketch code file. i did not included in any other files. i am newbie in arduino and c++ please can you tell me in more detail.
Thank You
Nonsense. It's also included in the SIM800.cpp file two. Two includes == two instance of SoftwareSerial named sp. You should NOT be creating an instance of SoftwareSerial in the header file, or you need to take care that including it multiple times does not result in multiple instances of the SoftwareSerial class being created.
The sketch should be responsible for creating the SoftwareSerial instance that the SIM800 class uses.
thank i will try to update things as you said... and will update you ..
