I'm currently working on a project to get a Leonardo to report the state of multiple Joysticks to Windows. (This is to allow me to exceed the paltry 32 button limit per stick which windows imposes on a sim-pit controller.)
I'm modifying a HID descriptor which works to define a mouse, keyboard and joystick. However, every time I add additional joystick reports to the descriptor, windows starts giving me the amazingly generic and unhelpful "error 10" (device can not start.) This is the error given by a malformed HID descriptor, but I've tried many things, including an extremely simplified descriptor that I'm pretty certain is okay, and I still get the error.
Here's my current descriptor:
const u8 _hidReportDescriptor[] = {
#if KBAM_ENABLED
// Mouse
0x05, 0x01, // USAGE_PAGE (Generic Desktop) // 54
0x09, 0x02, // USAGE (Mouse)
0xa1, 0x01, // COLLECTION (Application)
0x09, 0x01, // USAGE (Pointer)
0xa1, 0x00, // COLLECTION (Physical)
0x85, 0x01, // REPORT_ID (1)
0x05, 0x09, // USAGE_PAGE (Button)
0x19, 0x01, // USAGE_MINIMUM (Button 1)
0x29, 0x03, // USAGE_MAXIMUM (Button 3)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
0x95, 0x03, // REPORT_COUNT (3)
0x75, 0x01, // REPORT_SIZE (1)
0x81, 0x02, // INPUT (Data,Var,Abs)
0x95, 0x01, // REPORT_COUNT (1)
0x75, 0x05, // REPORT_SIZE (5)
0x81, 0x03, // INPUT (Cnst,Var,Abs)
0x09, 0x30, // USAGE (X)
0x09, 0x31, // USAGE (Y)
0x09, 0x38, // USAGE (Wheel)
0x15, 0x81, // LOGICAL_MINIMUM (-127)
0x25, 0x7f, // LOGICAL_MAXIMUM (127)
0x75, 0x08, // REPORT_SIZE (8)
0x81, 0x06, // INPUT (Data,Var,Rel)
0xc0, // END_COLLECTION
// Keyboard
0x05, 0x01, // USAGE_PAGE (Generic Desktop) // 47
0x09, 0x06, // USAGE (Keyboard)
0x85, 0x02, // REPORT_ID (2)
0x05, 0x07, // USAGE_PAGE (Keyboard)
0x19, 0xe0, // USAGE_MINIMUM (Keyboard LeftControl)
0x29, 0xe7, // USAGE_MAXIMUM (Keyboard Right GUI)
0x95, 0x08, // REPORT_COUNT (8)
0x95, 0x06, // REPORT_COUNT (6)
0x25, 0x65, // LOGICAL_MAXIMUM (101)
0x19, 0x00, // USAGE_MINIMUM (Reserved (no event indicated))
0x29, 0x65, // USAGE_MAXIMUM (Keyboard Application)
0x81, 0x00, // INPUT (Data,Ary,Abs)
#endif
#ifdef JOYHID_ENABLED
0x09, 0x05, // USAGE (Joystick)
0xA1, 0x00, // COLLECTION (Physical)
0x85, 0x03, // REPORT_ID (3)
//Buttons:
0x29, 0x20, // USAGE_MAXIMUM (Button 32)
0x95, 0x20, // REPORT_COUNT (32)
0x55, 0x00, // UNIT_EXPONENT (0)
0x65, 0x00, // UNIT (None)
// 8 bit Throttle and Steering
0x05, 0x02, // USAGE_PAGE (Simulation Controls)
0x26, 0xff, 0x00, // LOGICAL_MAXIMUM (255)
0x09, 0xBB, // USAGE (Throttle)
0x09, 0xBA, // USAGE (Steering)
0x95, 0x02, // REPORT_COUNT (2)
// Two Hat switches
0x09, 0x39, // USAGE (Hat switch)
0x25, 0x07, // LOGICAL_MAXIMUM (7)
0x35, 0x00, // PHYSICAL_MINIMUM (0)
0x46, 0x3B, 0x01, // PHYSICAL_MAXIMUM (315)
0x65, 0x14, // UNIT (Eng Rot:Angular Pos)
0x75, 0x04, // REPORT_SIZE (4)
0x09, 0x30, // USAGE (x)
0x09, 0x31, // USAGE (y)
0x09, 0x32, // USAGE (z)
0x09, 0x33, // USAGE (rx)
0x09, 0x34, // USAGE (ry)
0x09, 0x35, // USAGE (rz)
0x95, 0x06, // REPORT_COUNT (2)
0x85, 0x04, // REPORT_ID (4) (This is important when HID_SendReport() is called)
//Buttons:
// Two Hat switches
0xc0 // END_COLLECTION
#endif
I've tried removing the keyboard/mouse reports (I don't need them but would have preferred to keep them as this is in a core class for the Arduino.) I've tried defining the report ID number at both the application and physical collection. I've read examples which are logically identical (only big defference is they are defining gamepads instead of joysticks).
I'm assuming I'm missing something somewhere else which is required to make my expanded descriptor compatible with the device (Like a size definition or something - this is my first time working with USB HIDs).
Anyone have any idea what's going on?
My next step is to tear everything down and see if I can get just a single button on 2 separate joysticks working, but I'm not hopeful.
