I have this Schematic for a RC522 and micro SD card.
The problem happens very early in the program in the setup() function.
If I disconnect one of the devices the other works properly but not at the same time. I think the problem is how I select the slave with the SS pins. Here is my code. What can be wrong?.
#include <SPI.h>
#include <MFRC522.h>
#include <SD.h>
// Pines SPI
#define SS_RF 10
#define RST_PIN 9
#define SS_SD 8
// Instancia a la clase MFRC522
MFRC522 mfrc522(SS_RF, RST_PIN);
File Registro;
void EscribirArchSer(String cad)
digitalWrite(SS_SD,LOW);
digitalWrite(SS_RF,HIGH);
Serial.println(cad);
Registro = SD.open("status.txt", FILE_WRITE);
if(Registro){
Registro.println(cad);
Registro.close();
digitalWrite(SS_SD,HIGH);
digitalWrite(SS_RF,LOW);
while (!Serial);
SPI.begin();
delay(50);
mfrc522.PCD_Init();
mfrc522.PCD_DumpVersionToSerial();
delay(50);
delay(50);
Serial.println("Iniciando SD...");
if (!SD.begin(SS_SD)) {
Serial.println("Fallo de Inicializacion");
return;
Serial.println("Inicializacion Correcta");
delay(50);
EscribirArchSer("#############################################");
EscribirArchSer("################ RESET PLACA ################");
EscribirArchSer(F("Acerca la tarjeta al lector para escanear."));
EscribirArchSer(F("Comprobando las claves:"));
EscribirArchSer("Key-A: ");
EscribirArchSer(mostrarByteArray(keyA.keyByte, MFRC522::MF_KEY_SIZE));
EscribirArchSer("Key-B: ");
EscribirArchSer(mostrarByteArray(keyB.keyByte, MFRC522::MF_KEY_SIZE));
The Error I get:
