Multiple DHT22 on UNO with Adafruit Data logger shield
Hallo
I have tried to make a sketch that logs DHT22 temperature and humidity from 7 sensors. I can only make it to 6 working sensors, if i have all 7 going the SD file is blank, the serial monitor, shows all data... I have not connected more than 2 DHT22, so the rest of the data is reported as nan.
if i uncomment "ASG5" or "ASG4" it works fine, and i get SD and monitor data on 6 sensors, but with 7 sensors only serial monitor data but a blank file on the SD card, data logging is every 30 seconds...
Serial monitor looks like this:
Initializing SD card...card initialized.
Logging to: LOGGER18.CSV
datetime,rh,temp_c
,11/25/2021 08:39:27,Ref, 47.10,20.50,ASG 1, nan,nan,ASG 2, nan,nan,ASG 3, nan,nan,ASG 4, nan,nan,ASG 5, nan,nan,ASG 6, nan,nan
,11/25/2021 08:39:57,Ref, 38.70,20.60,ASG 1, nan,nan,ASG 2, nan,nan,ASG 3, nan,nan,ASG 4, nan,nan,ASG 5, nan,nan,ASG 6, nan,nan
I tried different approachs, and this is the nearest i got... my code is propably very infant;-)
Any suggestions to what is wrong?
I will try wiring up all sensors and hope it just a question on one nan to many....
best regards
Jan
// log DHT sensor readings to SD card
#include "DHT.h"
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
RTC_PCF8523 RTC;
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL  30000 // mills between entries (reduce to take more/faster data)
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define REF 7     // what pin we're connected to
#define ASG1 8
#define ASG2 9
#define ASG3 5
#define ASG4 1
#define ASG5 2
#define ASG6 6
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(REF, DHTTYPE);
DHT dht1(ASG1, DHTTYPE);
DHT dht2(ASG2, DHTTYPE);
DHT dht3(ASG3, DHTTYPE);
DHT dht4(ASG4, DHTTYPE);
DHT dht5(ASG5, DHTTYPE);
DHT dht6(ASG6, DHTTYPE);
// select 10 for adafruit shield
const int chipSelect = 10;
// create file to log to
File logfile;
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  if (! logfile) {
    Serial.println("could not create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
    logfile.println("RTC failed");
#if ECHO_TO_SERIAL
    Serial.println("RTC failed");
#endif  //ECHO_TO_SERIAL
  logfile.println("datetime,rh,temp_c");
#if ECHO_TO_SERIAL
  Serial.println("datetime,rh,temp_c");
  dht.begin();
  DateTime now;
  delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
  String dataString = "";
  // fetch the time
  now = RTC.now();
  // log time
  //logfile.print(now.unixtime()); // seconds since 1/1/1970
  logfile.print(",");
  if (now.month() < 10) {
    logfile.print(0, DEC);
  logfile.print(now.month(), DEC);
  logfile.print("/");
  if (now.day() < 10) {
  logfile.print(now.day(), DEC);
  logfile.print("/");
  logfile.print(now.year(), DEC);
  logfile.print(" ");
  if (now.hour() < 10) {
  logfile.print(now.hour(), DEC);
  logfile.print(":");
  if (now.minute() < 10) {
  logfile.print(now.minute(), DEC);
  logfile.print(":");
  if (now.second() < 10) {
  logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
 // Serial.print(now.unixtime()); // seconds since 1/1/1970
  Serial.print(",");
    Serial.print(0, DEC);
  Serial.print(now.month(), DEC);
  Serial.print("/");
  Serial.print(now.day(), DEC);
  Serial.print("/");
  Serial.print(now.year(), DEC);
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(":");
  Serial.print(now.minute(), DEC);
  Serial.print(":");
  Serial.print(now.second(), DEC);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity(); // relative humidity, %
  float t_c = dht.readTemperature(); // air temp, degC
  float h1 = dht1.readHumidity(); // relative humidity, %
  float t_c1 = dht1.readTemperature(); // air temp, degC
   float h2 = dht2.readHumidity(); // relative humidity, %
  float t_c2 = dht2.readTemperature(); // air temp, degC
   float h3 = dht3.readHumidity(); // relative humidity, %
  float t_c3 = dht3.readTemperature(); // air temp, degC
 float h4 = dht4.readHumidity(); // relative humidity, %
 float t_c4 = dht4.readTemperature(); // air temp, degC
 float h5 = dht5.readHumidity(); // relative humidity, %
 float t_c5 = dht5.readTemperature(); // air temp, degC
 float h6 = dht6.readHumidity(); // relative humidity, %
 float t_c6 = dht6.readTemperature(); // air temp, degC
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t_c) || isnan(h)) {
    Serial.println("Failed to read from DHT");
    logfile.print(",");
    logfile.print("Ref");
    logfile.print(",");
    logfile.print(h, 2);
    logfile.print(",");
    logfile.print(t_c, 2);
    logfile.print(",");
    logfile.print("ASG 1");
    logfile.print(",");
    logfile.print(h1, 2);
    logfile.print(",");
    logfile.print(t_c1, 2);
    logfile.print(",");
    logfile.print("ASG 2");
    logfile.print(",");
    logfile.print(h2, 2);
    logfile.print(",");
    logfile.print(t_c2, 2);
    logfile.print(",");
    logfile.print("ASG 3");
    logfile.print(",");
    logfile.print(h3, 2);
    logfile.print(",");
    logfile.print(t_c3, 2);
    logfile.print(",");
    logfile.print("ASG 4");
    logfile.print(",");
   logfile.print(h4, 2);
    logfile.print(",");
   logfile.print(t_c4, 2);
    logfile.print(",");
    logfile.print("ASG 5");
    logfile.print(",");
   logfile.print(h5, 2);
    logfile.print(",");
    logfile.print(t_c5, 2);
    logfile.print(",");
    logfile.print("ASG 6");
   logfile.print(",");
 logfile.print(h6, 2);
 logfile.print(",");
logfile.print(t_c6, 2);
#if ECHO_TO_SERIAL
    Serial.print(",");
    Serial.print("Ref, ");
    Serial.print(h, 2);
    Serial.print(",");
    Serial.print(t_c, 2);
    Serial.print(",");
    Serial.print("ASG 1, ");
    Serial.print(h1, 2);
    Serial.print(",");
    Serial.print(t_c1, 2);
     Serial.print(",");
    Serial.print("ASG 2, ");
    Serial.print(h2, 2);
    Serial.print(",");
    Serial.print(t_c2, 2);
      Serial.print(",");
    Serial.print("ASG 3, ");
    Serial.print(h3, 2);
    Serial.print(",");
    Serial.print(t_c3, 2);
          Serial.print(",");
    Serial.print("ASG 4, ");
  Serial.print(h4, 2);
    Serial.print(",");
  Serial.print(t_c4, 2);
              Serial.print(",");
    Serial.print("ASG 5, ");
  Serial.print(h5, 2);
    Serial.print(",");
   Serial.print(t_c5, 2);
    Serial.print(",");
    Serial.print("ASG 6, ");
 Serial.print(h6, 2);
    Serial.print(",");
 Serial.print(t_c6, 2);
  logfile.println();
#if ECHO_TO_SERIAL
#endif // ECHO_TO_SERIAL
  // flush to file
  logfile.flush();
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
From memory, pin 12 is MISO, which is needed to correctly receive responses from the SD card. Have you tried assigning ASG4 to a different pin?
And please use the the code tags when posting your code.
Sorry for messy post...
And thanks for answering.
Citatblok From memory, pin 12 is MISO, which is needed to correctly receive responses from the SD card. Have you tried assigning ASG4 to a different pin?
I tried to change ASG4 Pin 12 to Pin 1, no change, still no SD card data, serial port data are ok.
So any other suggestions are more than welcome.
Best regards
Jan
Ok got to 6 functioning sensors.....The code above dos not work;-)
#include "DHT.h"
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
RTC_PCF8523 RTC;
#define LOG_INTERVAL  300000 // mills between entries (reduce to take more/faster data)
#define S1 8
#define S2 9
#define S3 5
#define S4 6
#define S5 3
//#define S6
//Tried Pin 2, 4, 11,12,13 SD file gets corupt or is empty
DHT dht1(S1, DHTTYPE);
DHT dht2(S2, DHTTYPE);
DHT dht3(S3, DHTTYPE);
DHT dht4(S4, DHTTYPE);
DHT dht5(S5, DHTTYPE);
//DHT dht6(S6, DHTTYPE);
File logfile;
    return;
  if (! logfile) {
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
#if ECHO_TO_SERIAL
#if ECHO_TO_SERIAL
  dht.begin();
  dht1.begin();
  dht2.begin();
  dht3.begin();
  dht4.begin();
  dht5.begin();
  //dht6.begin();
  DateTime now;
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(",");
  logfile.print("/");
  logfile.print("/");
  logfile.print(" ");
  logfile.print(":");
  logfile.print(":");
#if ECHO_TO_SERIAL
  Serial.print(",");
  Serial.print("/");
  Serial.print("/");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
 //float h6 = dht6.readHumidity(); // relative humidity, %
 //float t_c6 = dht6.readTemperature(); // air temp, degC
    logfile.print(",");
    logfile.print(",");
   logfile.print(h, 1);
    logfile.print(",");
    logfile.print(t_c, 1);
    logfile.print(",");
    logfile.print("S1");
    logfile.print(",");
    logfile.print(h1, 1);
    logfile.print(",");
    logfile.print(t_c1, 1);
    logfile.print(",");
    logfile.print("S2");
    logfile.print(",");
    logfile.print(h2, 1);
    logfile.print(",");
    logfile.print(t_c2, 1);
logfile.print(",");
    logfile.print("S3");
    logfile.print(",");
    logfile.print(h3, 1);
    logfile.print(",");
    logfile.print(t_c3, 1);
    logfile.print(",");
    logfile.print("S4");
    logfile.print(",");
   logfile.print(h4, 1);
    logfile.print(",");
   logfile.print(t_c4, 1);
   logfile.print(",");
    logfile.print("S5");
    logfile.print(",");
   logfile.print(h5, 1);
    logfile.print(",");
    logfile.print(t_c5, 1);
    logfile.print(",");
  //  logfile.print("S6");
  // logfile.print(",");
// logfile.print(h6, 1);
 logfile.print(",");
//logfile.print(t_c6, 1);
#if ECHO_TO_SERIAL
    Serial.print(",  ");
    Serial.print(h, 1);
    Serial.print("% ");
    Serial.print(t_c, 1);
    Serial.print("°C ");
    Serial.print("S1, ");
   Serial.print(h1, 1);
    Serial.print("% ");
   Serial.print(t_c1, 1);
    Serial.print("S2, ");
    Serial.print(h2, 1);
    Serial.print("% ");
    Serial.print(t_c2, 1);
    Serial.print("S3, ");
    Serial.print(h3, 1);
    Serial.print("% ");
    Serial.print(t_c3, 1);
    Serial.print("S4, ");
  Serial.print(h4, 1);
    Serial.print("% ");
  Serial.print(t_c4,1);
    Serial.print("S5, ");
  Serial.print(h5, 1);
    Serial.print("% ");
   Serial.print(t_c5, 1);
   //Serial.print("S6, ");
// Serial.print(h6, 1);
   // Serial.print("% ");
// Serial.print(t_c6, 1);
//Serial.print("°C");
  logfile.println();
#if ECHO_TO_SERIAL
  // flush to file
  logfile.flush();
How much memory does the compiler show as being used?
For this working version 19584 of the maximum 32256....
and 19834 with the extra sensor...
Is it a Pin problem?
I havent found any info on Pin 2?
4 and 10 is used by the RTC/SD
11 MOSI
12 MISO
13 SCK
And i have no clue if the above means ocupied;-)
How much dynamic memory (ram) usage? The SD library needs to allocate 512 bytes at runtime for a buffer.
Ok, had a chance to compile your code. Dynamic memory usage of 1440 bytes, leaving 608 bytes available. You declare 12 floats in loop, which takes another 48 bytes, leaving 560. The SD library needs 512 for a buffer, leaving only 48 bytes, which is apparently barely sufficient since adding an additional DHT22 causes problems.
You can save a considerable amount of memory by using the F() macro when printing text literals.
  //Serial.print("Initializing SD card...");
  Serial.print(F("Initializing SD card...")); //stores text in program memory instead of RAM
david_2018 thank you very much, that was the problem. Thanks for being kind and helping a guy in need, your kind makes the world a better place :pray:
I deleted all the serial logging, dont need it....
#include "DHT.h"
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
RTC_PCF8523 RTC;
#define LOG_INTERVAL  10000 // mills between entries (reduce to take more/faster data)
#define S1 8
#define S2 9
#define S3 5
#define S4 6
#define S5 3
#define S6 2
//Don't use, 4, 10,11,12,13
File logfile;
    return;
  if (! logfile) {
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
#if ECHO_TO_SERIAL
#if ECHO_TO_SERIAL
  dht.begin();
  dht1.begin();
  dht2.begin();
  dht3.begin();
  dht4.begin();
  dht5.begin();
  dht6.begin();
  DateTime now;
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(",");
  logfile.print("/");
  logfile.print("/");
  logfile.print(" ");
  logfile.print(":");
  logfile.print(":");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
   logfile.print(",");
    logfile.print(",");
    logfile.print(",");
    logfile.print(",");
   logfile.print(",");
 logfile.print(",");
  logfile.println();
#if ECHO_TO_SERIAL
  // flush to file
  logfile.flush();
