Hi all, Could use a little help integrating 2 codes, Ill show my attempt at integrating
them but I am not satisfied with how the code looks or my understanding of it.
Here is the code Id found and made fit based on what I was looking for on the DHT22 side.
4X DHT22 sensors, I know of arrays but using its a problem since it does not label the
sensors.
#include <DHT.h>;
//Constants
#define DHTPIN1 28 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
#define DHTPIN2 29
#define DHTPIN3 30
#define DHTPIN4 31
DHT dht1(DHTPIN1, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
DHT dht2(DHTPIN2, DHTTYPE);
DHT dht3(DHTPIN3, DHTTYPE);
DHT dht4(DHTPIN4, DHTTYPE);
//Variables
int chk;
float hum1; //Stores humidity value
float temp1; //Stores temperature value
float hum2;
float temp2;
float hum3;
float temp3;
float hum4;
float temp4;
dht1.begin();
dht2.begin();
dht3.begin();
dht4.begin();
//Read data and store it to variables hum and temp
hum1 = dht1.readHumidity();
temp1= dht1.readTemperature();
hum2 = dht2.readHumidity();
temp2= dht2.readTemperature();
hum3 = dht3.readHumidity();
temp3= dht3.readTemperature();
hum4 = dht4.readHumidity();
temp4= dht4.readTemperature();
//Print temp and humidity values to serial monitor
Serial.print("Sensor 1: Humidity: ");
Serial.print(hum1);
Serial.print(" %, Temp: ");
Serial.print(temp1);
Serial.println(" Celsius");
Serial.print("Sensor 2: Humidity: ");
Serial.print(hum2);
Serial.print(temp2);
Serial.print("Sensor 3: Humidity: ");
Serial.print(hum3);
Serial.print(temp3);
Serial.print("Sensor 4: Humidity: ");
Serial.print(hum4);
Serial.print(temp4);
delay(2000); //Delay 2 sec.
4X DS18B20 on one wire bus , This wasn't modified much at all from a code I found on
this forum. I know its not needed for Fahrenheit since I am only really using Celsius.
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into digital pin 34 on the Arduino
#define ONE_WIRE_BUS 34
// Setup a oneWire instance to communicate with any OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass oneWire reference to DallasTemperature library
DallasTemperature sensors(&oneWire);
int deviceCount = 0;
float tempC;
void setup(void)
sensors.begin(); // Start up the library
// locate devices on the bus
Serial.print("Locating devices...");
Serial.print("Found ");
deviceCount = sensors.getDeviceCount();
Serial.print(deviceCount, DEC);
Serial.println(" devices.");
Serial.println("");
void loop(void)
// Send command to all the sensors for temperature conversion
sensors.requestTemperatures();
// Display temperature from each sensor
for (int i = 0; i < deviceCount; i++)
Serial.print("Sensor ");
Serial.print(i+1);
Serial.print(" : ");
tempC = sensors.getTempCByIndex(i);
Serial.print(tempC);
Serial.print((char)176);//shows degrees character
Serial.print("C | ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
Serial.println("F");
Serial.println("");
This is as far as I had gotten on the amalgamation of both these codes.
But I am really not happy with it or where its going? If that makes sense.
//Libraries
#include <DHT.h>;
//Constants
#define ONE_WIRE_BUS 2
#define DHTPIN2 29
#define DHTPIN3 30
#define DHTPIN4 31
//Variables
float tempC;
int chk;
float hum2;
float temp2;
float hum3;
float temp3;
float hum4;
float temp4;
dht1.begin();
dht2.begin();
dht3.begin();
dht4.begin();
Serial.println("");
Serial.print(i+1);
Serial.print(hum1);
Serial.print(hum2);
Serial.print(hum3);
Serial.print(hum4);
Could I please have some help regarding my code and integrating them together.
Any help or advice would be appreciated. I need to have all sensors labelled.
Is there any way to also identify my DS18B20 sensors? So for Eg Sensor 1 remains
as sensor 1 ? there was some mention of Identity on the sensors but i dont know
how to fetch or use them. you will see in the amalgamated code has mention of
3 DS18B20 sensors with ID's but I had to remove it since mine dont have this ID.
Thanks again,
Greetings from South Africa
