Hey All,
I recently started updating a wired sensor network I had that would values from different fish tanks and broadcast them to be read off a serial port by Putty. For this project, I had an Uno and a Teensy 3.1. Both had multiple DS18b20 sensors attached, and had a relatively low rate of errors (<5%).
As part of my summer internship, I learned how to use the data visualization suite ELK (ElasticSearch, Logstash and Kibana), and wanted to start using them for my project.
I now have four Unos (Two with two DS18b20s, one with one, and one with a DHT11). Each one has an nrf24L01 2.4Ghz receiver (and those all seem to work fine).
The DS18b20's are sending me back an error of "185.00F" (85C). When I unplug either the power or ground, I get "-196.60F" (I expected this). I have checked my wiring and connections, and they appear to be in the exact same places as the old system. I am also using the same sensors & long-distance wires (the longest is maybe 18 feet long).
Here's a sample sketch (each Unp + DS18b20 runs a slightly modified version of this):
//Packet Two - Waterproof Sensors
#include <DallasTemperature.h>
#include <OneWire.h>
//Need for both. These are the radio libraries:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24_config.h>
//If using the DS18b20 (OneWire) protocol, include the following. If using the DHT protocol, delete the following:
//Data wire is plugged into pin 7 on the Arduino
#define ONE_WIRE_BUS 7
//Setup a oneWire instance to communicate with any OneWire devices including non-IC/Dallas Temperature ones
OneWire oneWire(ONE_WIRE_BUS);
//Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
//Temperature Variable
float TempF0, TempF1;
//For nrf24 debugging
int serial_putc( char c, FILE * )
Serial.write( c );
return c;
//More nrf24 debugging
void printf_begin(void)
fdevopen( &serial_putc, 0);
//Pins the nrf24 will use to transmit and recieve data
RF24 radio(9,10);
//Only need a "write" pipe ATM, but will use it later
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL,0xF0F0F0F0D2LL};
//Can send up to 30 characters here:
char SendPayload[31] = ""; //What does this do?
//ONEWIRE ONLY:
pinMode(ONE_WIRE_BUS, INPUT);
//Start the serial
Serial.begin(57600);
Serial.println("Printing Tranmissions to Serial:");
printf_begin(); //What does this do?
//nRF24 configurations. Make sure they are the same on here and the Pi
radio.begin();
radio.setChannel(0x4c);
radio.setAutoAck(1); //What is AutoAck?
radio.setRetries(15,15); //What does this do? What does the (15,15) mean?
radio.setDataRate(RF24_250KBPS);
radio.setPayloadSize(32); //Is this 32 bits or 32 bytes?
radio.openReadingPipe(1,pipes[0]);
radio.openWritingPipe(pipes[1]);
radio.startListening();
radio.printDetails(); //For debugging
//For DS18b20 (OneWire) only:
sensors.begin();
therm0();
//Wait 30 seconds
delay(30000);
therm1();
//Wait 30 seconds
delay(30000);
void therm0(){
if (sensors.getTempFByIndex(0) == 196.00){
TempF0 = TempF0;
Serial.print("POWER ERROR! SENDING OLD VALUE!");
else if (sensors.getTempFByIndex(0) == 196.60){
TempF0 = TempF0;
else if (sensors.getTempFByIndex(0) == 32.00){
TempF0 = TempF0;
Serial.print("CODE ERROR! SENDING OLD VALUE!");
else if (sensors.getTempFByIndex(0) == 185.00){
TempF0 = TempF0;
Serial.print("WIRING ERROR! SENDING OLD VALUE!");
else{
TempF0 = sensors.getTempFByIndex(0);
//Asign TempF0 to payload, sending it as a string:
dtostrf(TempF0,2,2,SendPayload);
//Change the number after the "T" for eaach sensor. Follow the Numbering System.
strcat(SendPayload, "-T00"); //Tags to help sort the data (Value, Sensor)
//Send a heartbeat
radio.stopListening();
bool ok = radio.write(&SendPayload,strlen(SendPayload));
Serial.print("");
Serial.print("Sending: ");
Serial.println(SendPayload);
void therm1(){
if (sensors.getTempFByIndex(1) == 196.00){
TempF1 = TempF1;
else if (sensors.getTempFByIndex(1) == 196.60){
TempF1 = TempF1;
else if (sensors.getTempFByIndex(1) == 32.00){
TempF1 = TempF1;
else if (sensors.getTempFByIndex(1) == 185.00){
TempF1 = TempF1;
else{
TempF1 = sensors.getTempFByIndex(1);
//Asign TempF1 to payload, sending it as a string:
dtostrf(TempF1,2,2,SendPayload);
//Send a heartbeat
Serial.print("");
Any help would be much appreciated as I start school back on Tuesday again. If you need any more project background etc. or other relevant information to help please let me know!
Thanks!
