I have 4 ds18b20 sensors connected on one data wire. None of these sensors are showing up on the bus though?
/* YourDuino Multiple DS18B20 Temperature Sensors on 1 wire
Connections:
DS18B20 Pinout (Left to Right, pins down, flat side toward you)
- Left = Ground
- Center = Signal (Pin 2): (with 3.3K to 4.7K resistor to +5 or 3.3 )
- Right = +5 or +3.3 V
Questions: terry@yourduino.com
V1.01 01/17/2013 …based on examples from Rik Kretzinger
/-----( Import needed libraries )-----/
// Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
#include <OneWire.h>
//Get DallasTemperature Library here: http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
#include <DallasTemperature.h>
/-----( Declare Constants and Pin Numbers )-----/
#define ONE_WIRE_BUS_PIN 2
/-----( Declare objects )-----/
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS_PIN);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
/-----( Declare Variables )-----/
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress Probe01 = { 0x28, 0xFF, 0x11, 0x6F, 0x8B, 0x16, 0x03, 0xF4 };
DeviceAddress Probe02 = { 0x28, 0xFF, 0x76, 0x5B, 0x8B, 0x16, 0x03, 0xF2 };
DeviceAddress Probe03 = { 0x28, 0xFF, 0x06, 0x59, 0x8B, 0x16, 0x03, 0x98 };
DeviceAddress Probe04 = { 0x28, 0xFF, 0x74, 0x60, 0x8B, 0x16, 0x03, 0xAD };
void setup() /****** SETUP: RUNS ONCE ******/
// start serial port to show results
Serial.print("Initializing Temperature Control Library Version ");
Serial.println(DALLASTEMPLIBVERSION);
// Initialize the Temperature measurement library
sensors.begin();
// set the resolution to 10 bit (Can be 9 to 12 bits … lower is faster)
sensors.setResolution(Probe01, 10);
sensors.setResolution(Probe02, 10);
sensors.setResolution(Probe03, 10);
sensors.setResolution(Probe04, 10);
}//–(end setup )—
void loop() /****** LOOP: RUNS CONSTANTLY ******/
Serial.print("Number of Devices found on bus = ");
Serial.println(sensors.getDeviceCount());
Serial.print("Getting temperatures… ");
// Command all devices on bus to read temperature
sensors.requestTemperatures();
Serial.print("Probe 01 temperature is: ");
printTemperature(Probe01);
Serial.print("Probe 02 temperature is: ");
printTemperature(Probe02);
Serial.print("Probe 03 temperature is: ");
printTemperature(Probe03);
Serial.print("Probe 04 temperature is: ");
printTemperature(Probe04);
}//–(end main loop )—
/-----( Declare User-written Functions )-----/
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00)
Serial.print("Error getting temperature ");
Serial.print("C: “);
Serial.print(tempC);
Serial.print(” F: ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
}// End printTemperature
//( THE END )**
